Old 06-08-2015, 12:54 PM   #1
old Chevy guy
old Chevy guy's Avatar
Top of dash paint question?
When I gutted the cab that I rebuilt I noticed the top of the dash was flat black. I didn't really think that much of it thinking somebody spray bombed it or something But now as I'm robbing parts off my parts trucks to put this cab back together I notice that none of them seem to be color matched on top of the dash. Is that on purpose to limit glare from a glossy surface off the glass or what? getting ready to put in the glass and the dash pad so if I need to paint that area now's the time. Any info and paint color recommendations is appreciated , thanks.
old Chevy guy is offline   Reply With Quote
Old 06-08-2015, 01:27 PM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: Top of dash paint question?
I have seen them both flat black & the cab color but YES a matte finish to reduce glare ! My dash was light olive poly matte finish from the factory and I had the body shop duplicate it when my truck was painted.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 06-08-2015, 01:29 PM   #3
slomotion
Old Duffer
slomotion's Avatar
The flat, or matte color is a good thing to do. With the dash pad you won't see the the top of the dash from the driver's position, but you will see it as a reflection in the windshield. If you paint it with gloss I think the reflection may be a distraction.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 06-08-2015, 01:31 PM   #4
CUSTOM/10
CUSTOM/10's Avatar
Pictures before & after
Gary
72 SWB 4x4
My 72 SWB Build
Old 06-08-2015, 01:34 PM   #5
davepl
davepl's Avatar
Here's some trivia for you: it is NOT, from the factory, just the body color flattened. In the 2169 Dk Blue trucks (1970 at least) the blue is the same as some of my other blue cars (like a light blue Camaro). I -think- it's called GM Blue "Blue 13" flattened, but that's only from having looked at a faded one.
Now if you look at the PPG "interior colors" sheet it does just say body color flattened. This is the type of thing the NCRS guys care about, but I'm not -that- picky about. I still used the right blue, but had to point it out and get it redone before the glass went in. That interior sheet is 'incorrect' in a number of ways. For example the injection-molded console is not really body color, but the repaint code is just body color.
I can't verify this for all of the dash colors, just the blue. For all I know it was just cost savings since they already had that blue for other vehicles rather than one additional color in the plant. And it could be only some of the plants too. I know Oshawa and wherever my truck (F?) was built seem to have done it this way.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-08-2015, 01:36 PM   #6
michael bustamante
michael bustamante's Avatar
my 67 orange truck had red interior and the top of dash was painted a matte red to match the dash pad and the vents. I guess theres no orange interior
1967custom
michael bustamante is offline   Reply With Quote
Old 06-08-2015, 02:59 PM   #7
old Chevy guy
My truck is white so I think the glare is a very real problem even if it was flat. My work truck often has papers on the dash and it is a big distraction with the reflection.'unless somebody has better advice I think I may go with a matte black.
Old 06-08-2015, 03:27 PM   #8
SS Tim
SS Tim's Avatar
Generally they were painted a close match the color of the dash pad/interior in a zero gloss, flat paint. What trim color are you going with on your truck? What trim level is it?
There is another thread on why to use real paint and not just spray bomb this area.
SS Tim is offline   Reply With Quote
Old 06-08-2015, 03:30 PM   #9
FirstOwner69
FirstOwner69's Avatar
My 69 is maroon with a black interior and dash pad. The dash paint is flat or matte black between the pad and windshield. Of course, the rest of the interior paint is maroon.
Jim
FirstOwner69 is offline   Reply With Quote
Old 06-08-2015, 04:21 PM   #10
RenoKeene
Florida Edition
RenoKeene's Avatar
Body color, wet sand to knock the gloss off. Easy as pie.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 06-08-2015, 04:44 PM   #11
SS Tim
SS Tim's Avatar
Gary
In your before picture it appears that the foward dash is a faded dark olive color similar to what your roof was and would be the expected dash color with an olive interior. Do you have a picture of the original dash paint where it was covered by the pad?
Old 06-08-2015, 10:59 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Example of the OEM black dash as found in my K20
Old 06-09-2015, 01:10 AM   #13
Custom/Ten
Custom/Ten's Avatar
I always assumed that my dash was just sun faded. Thanks for the info guys!
Custom/Ten is offline   Reply With Quote
Old 06-09-2015, 07:24 AM   #14
CUSTOM/10
CUSTOM/10's Avatar
SS Tim,
No those are my only pictures, and the roof color was a repaint at sometime.
To me the dash appeared to be the light olive poly, but just dirty. When I got the truck there was no interior, it had been completely gutted out, I'm putting a black interior in.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 06-09-2015, 09:01 AM   #15
dfwright
dfwright's Avatar
My dash was painted to match the sandalwood dash pad. The truck's been in our family since it was new, and I'm pretty much certain that it came that way from the factory
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 06-09-2015, 09:56 AM   #16
old Chevy guy
The truck was a custom deluxe so it had the vinyl covered door panels with the scroll work. The dash pad and the column was light brown what I think might be called saddle. The "new" cab had a black dash pad and Column and the top off the dash appeared to be flat black. When I got it ,it was a freebee on Craig's list and there were no seats or doors so that's all I know about the inside. The outside was that medium kind off red. Im going to put a black dash pad in and I have a Black pair of Buddy Buckets from a 67 Im going to use. My steering wheel was already black so I'm just going to paint the Column to match. My old door panels are all beat up and have speaker holes cut in them. I have a good pair of metal ones I was thinking of painting black. I also have a set of good black seat belts. The whole thing is kind of a Hodge podge , The base truck was a 71 but the new cab is a 72. It had the 70 grill in it for a long time because that's what I had a good one of and liked it better too. It was going to be just a reworked work truck but the whole thing just got out of hand, its still going to be a work truck after its all done just nicer then I had planned and it wont be all accurate as far as year and options.
Old 06-09-2015, 09:58 AM   #17
68 TT
Still plays with trucks
68 TT's Avatar
My 68 C20 is referred to as bright red in the GM documents but it is every bit of Hugger orange inside & out. I guess they didn't have a better name for it in 67 & 68. They had another lighter orange that is more of a pastel color that they called orange so it wasn't that simple I guess.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 06-09-2015, 12:58 PM   #18
SS Tim
SS Tim's Avatar
SS Tim,
Gary
Thanks for the reply. Was going on the fact the cab looked to be a factory 556 med olive with a dark olive roof. In any event as before generally the forward dash is a flat dark color that matches the dash pad in most cases.
Old 06-09-2015, 01:09 PM   #19
SS Tim
SS Tim's Avatar
No the colors can be problematic.
The 514 Light Red often fades and photographs to an orange hue.
There have been many a truck I've found that I "wanted to be 524 Hugger Orange/Red Orange only to have the SPID confirm it was a 514.
516 Orange being a true orange is always clear.
Old 06-09-2015, 01:19 PM   #20
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
My 1972 GMC has flat black paint between the dash pad and the windshield. It's rubbed off in areas and the original green paint shows through. I assumed it was one of the PO's that did it since it looks to be a cruddy job.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-09-2015, 01:32 PM   #21
SS Tim
SS Tim's Avatar
Originally Posted by old Chevy guy View Post
...The "new" cab had a black dash pad and Column and the top off the dash appeared to be flat black... Im going to put a black dash pad in and I have a Black pair of Buddy Buckets from a 67 Im going to use. My steering wheel was already black so I'm just going to paint the Column to match... I have a good pair of metal ones I was thinking of painting black. I also have a set of good black seat belts...its still going to be a work truck after its all done just nicer then I had planned and it wont be all accurate as far as year and options.
Overall it sounds like a good combination of parts and in a very factory scheme. Flat black forward dash, gloss black column and door panels will give you a good looking white truck.
Here is a fairly good picture of a 71 Custom white/black metal door panel truck if it helps any.
Old 06-10-2015, 09:35 AM   #22
old Chevy guy
Looks good, about what I had envisioned. Only problem is now I want a spot light and flashing red light. I'm guessing that truck must be an old rescue or some type of fire apparatus ?
Old 06-10-2015, 12:23 PM   #23
Chuckin
Just cover the dash with shag carpet to reduce glare.
And hang disco ball from your mirror to go with it.
"Growing old is mandatory, Growing up is optional"
Chuckin - 68 Build Thread
Chuckin is offline   Reply With Quote
Old 06-10-2015, 01:22 PM   #24
SS Tim
SS Tim's Avatar
VFD brush truck.
