06-08-2015, 02:10 PM | #1 |
Axle mods while out
I am in the process of changing my rear axle bearings and seals. While I have the axles out is there any modifications recommended before re-installing them? I want to keep the 6 lug axles and I am in the process of pricing Torque Thrust ST's. Is the bore size an issue on the rear centering ring?
06-08-2015, 02:59 PM | #2 |
Re: Axle mods while out
possi ,, and disc brakes are nice add ons
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
06-08-2015, 03:18 PM | #3 |
I would do possi also.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
06-08-2015, 10:49 PM | #4 |
Defiantly do a posi or limited slip! Also a new ring and pinon gear. That is what I did when I rebuilt my rear axle.
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
06-09-2015, 01:10 PM | #5 | ||
"I ain't nobody, dork."
Limited slip = Posi-traction
An Eaton Posi-traction unit will be the best $400 bucks you can spend on your truck. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-09-2015, 10:48 PM | #6 |
I thought Posi-traction and a limited slip are different! Where a posi has issues when you make turns but a limited slip corrects that issue by allowing the inside wheel to slip when turning.
06-10-2015, 10:21 AM | #7 |
One of the First
Limited slip is locked like a full posi unit, until you turn and then internal clutch pack will let one axle slow or speed up with the turn or terrain undulation. Nothing like hearing a full posi "POP" while turning or backing. it will sound like you just blew your rear end.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
06-10-2015, 10:29 AM | #8 | ||
Limited Slip diffs by different names... all the same thing.
Chevrolet = Posi-traction Buick = Positive Traction Olds = Anti-spin Cadillac = Controlled Traction Pontiac = Safe-T-Track Ford = Traction Lock Chrysler = Sure Grip AMC = Twin-Grip Gary
06-10-2015, 10:30 AM | #9 |
An Eaton posi / limited slip has clutches that slip for cornering. A locker has no slippage and will chirp tires on corners.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
06-10-2015, 04:14 PM | #10 |
Assuming you have a stock cover, I would add a drain plug bung while you have a it off.
http://www.chassisunlimited.com/stor...rain-plug.html |
