03-26-2017, 09:23 AM | #1 |
72 K20, swap out the 350 for a BB468, bolt right in?
Just wondering, I have a 468/450HP sitting on a stand in my garage waiting for a candidate. Found a 72 K20 with a 350/350 in it. I'd like to just shoe horn the BB in it, my question is...it that a straight forward swap or am I going to have distributor, header and other problems. Trying to do a bit of homework before I pull the trigger on the K20
Thanks |
03-26-2017, 09:35 AM | #2 |
Re: 72 K20, swap out the 350 for a BB468, bolt right in?
I'd like to put this in the K20, it has since been pulled out of the 76 1 ton after only 5000 miles or so. I sold the 76 1 ton to my son but the engine stayed with me
Please excuse the hokey voice https://m.youtube.com/watch?v=HIVHPm...me_continue=63 |
03-26-2017, 09:35 AM | #3 | |
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
03-26-2017, 09:36 AM | #4 |
If you have all new cab mounts and stock valve covers, it's "should" fit. It will be tight though.
If you run small cap dizzy it will be fine, but you should be able to squeeze a big HEI cap in there as well. Can't comment on the headers as I don't know what headers you are trying to run. I say go for it. |
03-26-2017, 09:37 AM | #5 | |
Really you just need the TH400 and the right adapter and maybe a new input shaft for your T-case to make it work. |
03-26-2017, 10:40 AM | #6 |
All about them K’s
And machine work to the 205 housing. The input bearing for a 400 205 is bigger than the th350 and sm465.(late 80s 465 may be the same as a 400 I can't remember)
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-26-2017, 10:47 AM | #7 |
Here's a pic of the 205 you need it's off a 400 turbo but the 85-91 square body sm465 used the same 205 I've got 3 of these
03-26-2017, 12:43 PM | #8 |
Thank you all for the input, very helpful
03-26-2017, 02:09 PM | #9 |
All about them K’s
Thanks Jeff I was pretty sure the late 465 cases were the same.
