03-18-2018, 09:27 PM | #1 |
Throttle foot peddle bolts
I did a post about this a while back but can't find the original post or I would use that. I'm looking for the ball end bolts that the throttle foot pedal mounts to on the floor. Someone gave me some info on where to find them and I did buy a couple but, (not blaming anyone here) I didn't realize that there were quite a few different sizes of these. The ones I got had the right size ball on the end, but the threaded part wasn't correct, it was 1/4" and I need 5/16". I was at Summit Racing today and they couldn't help me. They suggested LMC and, I looked online but, couldn't find any. Does anyone know where I can find these? This is holding up finishing my truck. HELP!!!!
Thanks for any help! |
03-18-2018, 10:06 PM | #2 |
Re: Throttle foot peddle bolts
Speedway
03-18-2018, 10:08 PM | #3 |
One foot in front of the other
Truck and Car Shop- page 40
http://www.truckandcarshop.com/6072.html |
03-18-2018, 10:40 PM | #4 |
Brothers
03-18-2018, 11:08 PM | #5 |
Just ordered some from classic parts. accelerator ball studs.
03-18-2018, 11:25 PM | #6 |
03-18-2018, 11:25 PM | #7 | |
03-18-2018, 11:26 PM | #8 |
03-18-2018, 11:27 PM | #9 |
03-19-2018, 08:51 PM | #10 |
Well, I talked to an old forum friend and he answered some questions I had but, posted some new questions. He verified that 1/4" threads is what the threads should be in the floor but, really didn't have an answer for the fact that mine are 5/16. I did call Classic parts, Brothers trucks and speedway. The studs that these places had were all 1/4". So, if there is room, I'll put nuts and washers behind the floor on the studs I have and, push come to shove, I'll cut the threaded part off of the studs I have and weld 5/16" bolts on to that. There's more than one way to skin a cat!...lol Thanks to everyone for the help, it was much appreciated!
03-19-2018, 10:44 PM | #11 | |
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
03-20-2018, 12:37 PM | #12 |
These are what is stock, maybe you can heliarc ( I think that’s the term) if these are smaller size.
https://www.classicparts.com/mobile/...info/39%2D375/
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-20-2018, 03:37 PM | #13 | |
I'm just glad to be here!
I have this same problem with my '65. I ordered the ball studs form Classic Parts and they have 1/4"-20 threads and my holes are tapped for 5/16"-18 threads. I know that my truck is stock when it comes to this area, my grand father was the original owner (I've owned it now for 34 years) and it never had these replaced until I took them out many years ago when I switched to a cable throttle set up. I decided to just keep the cable throttle set up for now until I can find the right studs to use. Next time I order from McMaster Carr I might add two of these to my list to see if they will work. Shipping would be more than these two parts alone so I'll just wait till I have a larger order... https://www.mcmaster.com/#9512k63/=1c207md
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-20-2018, 11:04 PM | #14 | |
I'm
Edit: Just got off the phone with McMaster-Carr and ordered two of those bolts. It sure is weird that everyone else I've talked to has 1/4"x20 thread and, mine and aggie91, have 5/16x18 thread studs. A big thank you to aggie91 for posting up the info for those studs, it is MUCH APPRECIATED!!! Last edited by '65 chevy lover; 03-20-2018 at 11:36 PM. Reason: Extra info |
03-21-2018, 12:34 AM | #15 |
would a heli-coil work?
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
03-21-2018, 01:03 PM | #16 |
03-27-2018, 11:00 AM | #17 | |
03-27-2018, 02:17 PM | #18 |
Yep, worked perfectly. Wish I had thought about taking a picture. It'll be several days before I get back out to where my truck is but, when I do I'll take one and post it here.
