Old 09-01-2019, 08:36 AM   #1
CJ2A
CJ2A's Avatar
Fleet side wheel housing
Are wheel tub housings for a fleetside pickup available wider than stock. The wheels and tires I want to install need more room on the back side of the wheel, about 1” wider would be perfect.
CJ2A is offline   Reply With Quote
Old 09-01-2019, 03:13 PM   #2
CJ2A
CJ2A's Avatar
Re: Fleet side wheel housing
I see where I can get stock and some 4” wider, my question is can they be purchased 2” wider ? Or 3” wider ?
Old 09-01-2019, 03:33 PM   #3
shortstep60
I have not seen any two or three inch wider ones you will have to make you a set. Its not that hard to do if you have a welder and a grinder with a cut off wheel and buy another set of wheel tubs to add on to yours
shortstep60 is offline   Reply With Quote
