12-05-2019, 11:03 PM | #1 |
Battery Relocation / 70 Stepper
Im going to LS Swap my 70 stepper when it comes home from restoration shop and will need to relocate the battery due to the filter box I plan to use off our 2011 Silverado donor ,( not a stock box ) , can it be mounted under the bed like on a Fleetside ? Im also considering ordering an auxialliary battery box for a 4x4 for the driver side , Thoughts , or better ideas ?
12-06-2019, 12:28 PM | #2 | |
The Older Generation
Re: Battery Relocation / 70 Stepper
I used an auxiliary battery box on my '67 Chevy Panel Truck. It bolted right up and worked great. Under the bed would work if you have a heavy duty battery and use welding cable for the battery cables. I have the battery in my '39 Ford Coupe in the trunk and if the connections on the starter, frame or battery posts get a little corroded it cranks over really slow. LockDoc
12-06-2019, 08:49 PM | #3 |
laying low
John I was going to suggest you find the auxiliary under hood battery tray so to keep the cables shorter and be much easier to get to than under the bed.
12-07-2019, 12:29 AM | #4 |
Thanks guys , that Auxiliary Battery tray is the way I will go . Im hoping to start blowing that truck apart as soon as it comes home . I will order a tray shortly .
