Old 10-30-2019, 09:54 PM   #1
bcfishon
Where are the usual rust spots 4 suburbans?
So I scored this awesome suburban the other day and was thinking about flipping it untill I drove it,I simply love it and now I contemplating keeping it. I am well versed in trucks and a little experience with the Blazers but this is my first suburban and the rust is showing up differently than what I'm used to. The rockers seem to be rotting from the outside in rather than the usually door sill area. I also noticed rust starting at the inside roof top where it meets the windshield and behind the rear seat where the front bed wall meets the flooring. Pretty obvious why the rear quarters are starting to rust at the inside floor level. Are there other areas that are typically problem spots for rust that I need to look for on this particular body style?.
bcfishon is offline   Reply With Quote
Old 10-30-2019, 10:04 PM   #2
bcfishon
Re: Where are the usual rust spots 4 suburbans?
Here a few pictures.
Old 10-31-2019, 06:44 AM   #3
Bigdav160
Bigdav160's Avatar
Like you, I've had several pickups and a Jimmy before buying my Suburban. I regretted selling that one so I bought another. The rust problems are the same as a pickup with the exception of the kickup area behind the middle seat. Looks like your roof seam sealer has broken down.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-31-2019, 01:21 PM   #4
HO455
HO455's Avatar
Good morning neighbor. All of the above items and the rear hatch and gate are problematic if you have them, more so than barn doors which would be similar to the pickup doors as far as rust. Oh and the taillight housings are in a box that can fill up with dirt and rust out.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 11-01-2019, 03:09 PM   #5
BGarza13x
The spot for the spare tire was rusted through on mine. Low to the ground and accumulates water when the hatch had a leak. Then i had the normal stuff, rockers and floor near it, windshield, around the tire wells on the outside. Drip rails too, I think My body guy said the a pillar support under the fender/door was bad too.
BGarza13x is offline   Reply With Quote
Old 11-03-2019, 03:51 PM   #6
Franks 72
Active Member
Franks 72's Avatar
Rust through in the vertical floor portion under the rear seat was the bigest issue for me (as shown It was an indicator of issues with the large crossmember and crossmember to inner sill fastening points. I think many suburbans suffer from this since moisture gets trapped between crossmember and the spot welded floor vertical piece . I fixed mine but it was a huge job. Check the condition of body at ends of crossmember.
Franks 72 is offline   Reply With Quote
Old 11-17-2019, 12:06 PM   #7
1968k20
1968k20's Avatar
I've got parts for this
Floor pan section
Firewall
Left and right wheel wells
Roof skin
The barn
Doors
We could meet half-way!
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 11-17-2019, 12:07 PM   #8
1968k20
1968k20's Avatar
Floor pan section
Firewall
Roof skin
The barn
Doors
I also have the whole left section from drivers door back back, also some other misc parts suburban-only
