01-27-2021, 03:46 PM | #1 |
Electrical issue/help
So I installed an electrical fan on my 84 swap and used the pink wire to supply the 12v key power to the relay from the bulkhead. Fan turn on and off with the key. The issue im having is if I turn on the lights and flip the turn signal to the right the fan turns on without the key. If I unplug the column connector its back normal. I been trying to figure the wire diagrams but electrical is not my strong area. I also noticed that emergency flasher won't work with the lights on. Thinking it is all related.
01-28-2021, 02:29 PM | #2 |
Re: Electrical issue/help
So I have a test light and tested for current. When I turn on lights the grey wire that goes to the cluster has power which is normal because is the lights 12v. But the dark blue cable (right turn) also has power. So it getting 12v from somewhere.
01-28-2021, 04:38 PM | #3 |
Headlight switch is what changes the power to the lights. Not sure about your fan issue. Are you running the fans thru a relay and just using the pink lead as exciter lead?
01-28-2021, 04:58 PM | #4 | |
01-28-2021, 05:01 PM | #5 |
This may help some. It appears the pink lead feeds the fuse box and one of theose feeds goes to the dark blue wire which feed the flasher and eventually ends up thru headlight switch and up to your right turn/park lights.
Maybe you should get your fan pwr from one of the open switched connectors on the fuse box. Your fan wiring I think Is just giving another path for the blue wire to go to to get a ground. Just a guess, but all I can think of at the moment.
01-28-2021, 05:50 PM | #6 |
I disconnected the pink wire from the relays. But the right turn signal and emergency flasher still don't work with the lights on
01-28-2021, 06:48 PM | #7 |
Rule 1 for weird automotive electrical issues is verify that all grounds are good.
Rule 2 is check for corrosion. After 30+ years, it is a rare turn signal or head light that doesn't have one or more corrosion issues. Especially for wires ran to ground screws. Most grounds involve bare metal and star washers that often react poorly to years of salt and moisture. A lot of automotive circuits share wires and if a ground is bad, the current will back feed though a 2nd device to find a ground. |
