02-13-2020, 05:46 PM | #1 |
Engine compartment done
I fired up my Gen IV 5.3 last weekend for the first time but I had to cobble together the air intake temporarily. Today the mailman brought me a 4" elbow that had long enough legs to allow me to clear the alternator. I heard the MAF likes a straight run so I centered it. My plan was always to have the top rad hose on the passenger side and the air intake to the drivers side, partly to obstruct the ECM and the associated mess of wires. I also made a block off for the big hole in the front ps of the engine cover and painted the cover with black vinyl paint to brighten it up. No deluxe heater makes for a cleaner look as well.
02-13-2020, 06:35 PM | #2 |
Re: Engine compartment done
Very nice moe...
02-14-2020, 01:40 PM | #3 |
Looks nice and clean!
What kind of radiator did you go with? Inlet/outlet sizes? Upper and lower hose part #'s?
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
02-14-2020, 02:20 PM | #4 |
Where’d you get your intake?
02-14-2020, 07:46 PM | #5 |
Looks clean!
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-14-2020, 08:15 PM | #6 |
looks moe bettah than factory
02-16-2020, 10:49 PM | #7 |
Roto Reuter thats the name...
Looks great! I'm with MDPotter. I'd like to know info on your radiator, inlet/outlet sizes and hose PN's. I'm at a point where I'm trying to figure out radiator hoses for my K10 5.3L Gen III swap. Any info is greatly appreciated.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
02-17-2020, 05:52 PM | #8 |
02-17-2020, 06:10 PM | #9 | |
Upper rad hose is Gates 21970 that I had to shorten 3 1/2". 1 1/2" rad x 1 1/4" engine Lower rad hose is Continental 61416 My motor is Gen IV. Not sure if that makes a difference for the hoses. Last edited by bigmoe; 03-05-2020 at 11:55 AM. Reason: add more |
02-18-2020, 01:47 PM | #10 |
I should add that someone on here used a Continental 64143 for a top hose but for my Gen IV it was too short and too small at one end. Fits Gen III maybe?
02-18-2020, 01:54 PM | #11 |
Oh you mean the air intake? I just cobbled it together using an elbow, some 4" tube and a 4" filter I bought on Ebay. I had to hunt a bit to find an elbow long enough so it would clear the alternator. The Maf is stock. It's actually a bit smaller than 4". One end I was able to hose clamp down, but the other end was even smaller so I cut a plastic strip and wrapped and glued it around to bring up the diameter.
07-28-2020, 01:48 PM | #12 |
I'm late to this but looks great Moe! Curious to know if you always planned to mount your ECM where it is. I've got a stock harness as well and have the same engine cover (L96) but want to route my harness and ecm either to back firewall or against the firewall in the cab.
07-28-2020, 06:34 PM | #13 |
I had the stock harness thinned out but that’s the stock routing direction so I didn’t have much choice where the ECM mounted. The air filter hides it a bit. It would take a lot of work to re route a stock harness to move the ECM location but you can buy aftermarket ones that will work for what you want.
Did you notice the block off I made for the front ps of the engine cover? |
