Old 02-25-2015, 10:59 PM   #1
72_K10_Vegas
72_K10_Vegas's Avatar
700-R4Transmission Cooling
Gents,
I have the following:
HBR (LasVegas) 383 Stroker built for low end (425 HP, 415 FtLbTq maybe more? not sure till the dyno)
700-R4 Transmission, built for towing (Vette servos yadda yadda)
Hughes lockup converter GM22LXTM
Hughes transmission cooler HP8231, with fan
RnD Radiator with transmission cooler option
My question is: What is the best way to run these tranny lines? I know that I will be generating high transmission / converter temps because of hauling those darn horses around the high country, but also, long trips in cold north country unloaded. I want the optimum transmission temperature.
Should I go transmission to radiator to transmission cooler? I have thought about a 3 way valve to cut in and cut out the transmission cooler depending on temperature.
Schematics are great / or verbal.
Any thoughts greatly appreciated.
72 K10
72_K10_Vegas is offline   Reply With Quote
Old 02-26-2015, 01:53 AM   #2
midnight rambler
midnight rambler's Avatar
Re: 700-R4Transmission Cooling
Did mine trans to radiator to trans cooler.
midnight rambler is offline   Reply With Quote
Old 02-26-2015, 02:59 AM   #3
72_K10_Vegas
That was my first thought as well.
What about expected temperatures? Leaving the transmission, leaving radiator, then cooler?
72 K10
Old 02-26-2015, 11:00 AM   #4
turp mcspray
turp mcspray's Avatar
On my vehicles with add on trans coolers, I block them off with a piece of cardboard in the wintertime.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
