Old 08-09-2020, 05:08 PM   #1
badherb
badherb's Avatar
Headliner
Have a 60 swb. The headliner is metal as everyone knows. I wanted to install a fabric headliner foam backed ( gonna have upholstery guy do this). What I want to ask is there trim kit for the 60 I realize probably not but has someone did this and used something else or am I sol? Thanks
1960 SWB “Pops”
If you won't support our troops then stand in front of them!
badherb is offline   Reply With Quote
Old 08-10-2020, 12:38 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Headliner
I do not think that there is a factory headliner trim for the 60-66 trucks. If I'm wrong, I know someone will correct me
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 08-10-2020, 10:01 AM   #3
roll_the_dice
roll_the_dice's Avatar
Re: Headliner
I found this thread where someone made a headliner...
https://67-72chevytrucks.com/vboard/...ight=headliner
roll_the_dice is offline   Reply With Quote
Old 08-10-2020, 11:01 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Headliner
No, never seen an aftermarket unit.
Old 08-10-2020, 04:35 PM   #5
forestb
forestb's Avatar
Re: Headliner
I have a cloth and insulation headliner. Just so that I can have insulation on the ceiling. The upholsterer used velcro to hold it up. Glued one side to the ceiling and sowed the other onto the headliner. It worked well until the heat got to the glue and then it started falling down. Still trying to get the old glue off the ceiling so I can figure out a better glue to use.
forestb is offline   Reply With Quote
Old 08-11-2020, 01:03 AM   #6
AcampoDave
AcampoDave's Avatar
Re: Headliner
Hey, that's me! Thanks Dice Roller. I think that's the first time anyone besides me has linked one of my threads. The headliner is still doing well and isn't falling or sagging.
AcampoDave is offline   Reply With Quote
Old 08-11-2020, 12:46 PM   #7
kens65fb
Re: Headliner
[ATTACH][/ATTACH]
If you are going to have an upholstery shop make one for you, and install it, it's not going to be cheap, trust me.
I bought this one a while ago, it's 20% off again, that will take it down to $160.
Installation was a breeze, and the quality was great.
Goes great with my new door panelsName:  Screenshot (38).jpg
kens65fb is offline   Reply With Quote
Old 08-11-2020, 01:30 PM   #8
The Rocknrod
Moderator
Re: Headliner
Wow - What a find. Door panels look great too.
Old 08-11-2020, 04:00 PM   #9
kens65fb
Re: Headliner
The headliner is currently available in 8 colors, for $194.99 with an additional 20 % off at checkout.
Here is a pic of my seats & console
Old 08-11-2020, 04:48 PM   #10
verdell
verdell's Avatar
Smile Re: Headliner
How's it holding up? Velcro still holding it firm and secure? It looks like a great project and you did a A1 job but I'm concerned with it in the deep south heat. It's 98 degrees in the shade right now here in north MS and I don't keep my truck in a garage.
verdell is offline   Reply With Quote
Old 08-11-2020, 07:47 PM   #11
AcampoDave
AcampoDave's Avatar
Re: Headliner
Summer days regularly get into the triple digit temps where I live and on those days, my garage gets too hot to even spend time inside it. Nonetheless, the headliner stays put. One key to success is to choose a lightweight covering. I later tried to make a gray one out of some thick vinyl fabric and it was too heavy and the thing kept trying to come down. The black vinly stuff you see in my thread is suprisingly thin and light weight. Walmart regularly has plenty of different black vinyl styles but other colors can be a little sparse.
Old 08-11-2020, 08:05 PM   #12
AcampoDave
AcampoDave's Avatar
Re: Headliner
I used these https://www.amazon.com/Noico-Insulat...a-806533907915 under my carpet and they are super sticky squares of foam stuff. I got to wondering as I was applying them, if there would be some way to utilize them in constructing a headliner. If somehow they could be laid out to form and then covered pehaps with a lightweight piece of fiberboad or palstic that you would glue to the non-sticky side then maybe wrap it with vinyl or cloth using the peel and stick side on the back to hold the material where it wraps over. Then peel the paper away from the back of the product and stick it up there.
Old 08-12-2020, 12:49 PM   #13
jweb
jweb's Avatar
Re: Headliner
They likely used an adhesive backed Velcro. Be sure to get all of the glue off.
Then you can use Velcro with VHB backing or someone on the forum also suggested magnets.
Velcro with VHB: https://www.itapestore.com/3m-dual-l...-the-yard.html
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 08-12-2020, 12:58 PM   #14
forestb
forestb's Avatar
Re: Headliner
I was the magnet guy. I decided against it. What is VHB? Somebody else I know suggested using neoprene glue.
Old 08-12-2020, 01:28 PM   #15
jweb
jweb's Avatar
Re: Headliner
VHB ( very high bond) tape is what all of the emblems are attached with on new cars. It has been tested in very harsh environments and holds up well.
We use VHB tape and the VHB backed Velcro on quite a few parts when assembling the aircraft interiors we make at work.
Old 08-12-2020, 01:37 PM   #16
forestb
forestb's Avatar
Re: Headliner
I was just looking at the link you posted. This might not work for me because I already have the standard loop style sowed into the headliner. I will have to find a different one that is VHB backed.
Old 08-12-2020, 02:04 PM   #17
jweb
jweb's Avatar
Re: Headliner
How wide is the Velcro in your truck? I have some 1" width that will work with standard hook and loop with VHB here. I could send you some pieces of either the hook or loop that you need for free.
If the 1" will work just send me a PM, let me know if you need the hook or the loop and how long, also your address.
Old 08-12-2020, 07:36 PM   #18
WOLFMANmike
WOLFMANmike's Avatar
Re: Headliner
Originally Posted by kens65fb View Post
[ATTACH][/ATTACH]
Goes great with my new door panelsAttachment 2039853
Wait i just have 1 question how in the name of all that is holy do you roll down your windows and also open your door with those panels?
WOLFMANmike is offline   Reply With Quote
Old 08-12-2020, 07:48 PM   #19
kens65fb
Re: Headliner
These door panel have a strong waterproof fiberglass panel underneath the vinyl, not a fiberboard backing.
First install the door panel, then press the vinyl with your finger to find the shaft, that the handles attach to
Cut a small x with a razor into the vinyl, and push the vinyl to expose the shaft, then attach the handles, with the set screws
Neat & clean
Old 08-12-2020, 08:01 PM   #20
WOLFMANmike
Re: Headliner
hey bro i have this idea im gonna do when i make my head liner for my 65 c10 and i bet it would work well for you too and the heat should not matter so here it is i cant remember what its called but that real thin press board shape it to fit then your foam shape it to fit and last part most important Home depot has Neodymium magnets very strong and they happen to have counter sunk holes in the center of them see where im going here? so place your magnets where you want them then run a screw through the counter sunk hole into that thin press board do it with all the magnets then put a washer and a small nut to keep it from ever coming lose. now comes your foam so that the foam sits flush on its new press board backing use a exacto blade and cut the diameter of the magnet so that when you lay it over the magnets it covers it and sits flush now use the 3m dualloc velcro for your foam that stuff holds 25 lbs! put that on your foam backing and the press board and you my friend are all set!! the idea here is that #1 the strong magnets are holding up the whole thing and heat has no effect on the magnets power # 2 the press board and magnets will be absorbing the full brunt of the heat but your foam will not get as hot it will serve as a insulator and as long as you get strong enough magnets she aint gonna fall hot. cold. or not now i have not made mine yet but its just a idea in my head i thought ide share with you for yours and others who may be into it
Old 08-12-2020, 08:06 PM   #21
WOLFMANmike
Re: Headliner
Neat & clean
ahhhh ok got ya i was like wait a min here lol
Old 09-12-2020, 05:07 PM   #22
forestb
forestb's Avatar
Re: Headliner
Yay
Reinstalled my headliner for the first time sense last year with some VHB Velcro. Thanks jweb.
