Old 06-24-2014, 01:27 AM   #1
crazy longhorn
Fabricate till you "puke"
Dana 44 rear diff questions
A bud just purchased a 44 rear diff(Youkon 4.10 gears & a power loc diff), said to be set up to fit his 82 chevy shortbed. It bolted in, but due the drive shaft length issues, he tried to fit the original yolk from his 12 bolt (yikes, I wish he would have asked 1st)! At any rate, I know that the 12 bolt diff runs a crush collar...& that needs to be replaced, along with the pinion seal after the yolk is removed? The question is on the 44....does it run solid shims, tween the pinion bearings, or will it require a crush collar, to set the preload on the bearings? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-24-2014, 06:59 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Dana 44 rear diff questions
The Dana does not use a crush sleeve.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-24-2014, 06:55 PM   #3
crazy longhorn
Thanks Bigdave Longhorn
