02-13-2020, 02:38 PM | #1 |
BlahBlahBlah
Truck tail lights in a burb/panel
How many folks have put tail light assemblies out of pick ups in their burbs?
I think Rob did it and possibly Frizzle. Anyone else? Just do it for something different?
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
02-15-2020, 09:34 PM | #2 |
Re: Truck tail lights in a burb/panel
I am waiting for someone to put burb lights in their pickup
02-16-2020, 06:25 AM | #3 |
1967 Panel truck with recessed taillight housing and fleetside taillight lenses for flush fit to body.
Paul Jr. @ GMCPauls |
02-16-2020, 11:52 AM | #4 |
Gmcpaul, can you explain if this is a simple bolt in or what modifications are needed
02-16-2020, 12:07 PM | #5 |
The Older Generation
Here are the truck lights frenched into the rear of the '67 Panel. The reverse lights are also removed. As far as I'm concerned they set them in too far and I would have left the reverse lights but it was all done when I bought the truck.... LockDoc
02-17-2020, 05:53 AM | #6 |
Collector of Projects
Looks like the structure behind the light bucket was frenched in a body worked... Probably a lot or welding and fab involved...
02-18-2020, 06:24 AM | #7 | |
For someone to have recessed the lens as far as it was done on LockDoc's photo they must have removed all the metal directly behind housing to allow it to sit that far back into the body, you only have to remove enough metal to clear the oval shaped recess for taillight bulb then the metal behind housing ends up placing housing flush with body when lens is installed. If thats your vehicle LockDoc you might consider placing washers behind housing to space it out further to flush it with the body so it's no longer recessed. Paul Jr @ GMCPauls Last edited by GMCPaul; 02-18-2020 at 11:21 AM. |
02-18-2020, 11:12 AM | #8 | |
Thanks, LockDoc
02-19-2020, 04:31 AM | #9 |
Wes from Classic Heartbeat needs to chime in .. I think he had some custom ones made ….
02-24-2020, 11:14 AM | #10 |
BlahBlahBlah
I like the slightly sunken or flush stock tail light look that have been posted. But I also like the totally stock look.
