Old 04-02-2020, 05:51 PM   #1
cochino12
It followed me home?
cochino12's Avatar
I've got a couple new dually projects
Picked up the white c30 early last month, before and after pictures. I've already got the interior finished up also.
The red truck I bought for work because of the dump bed. Not running currently but my mechanic should have it going for me hopefully soon. I think I'm going to lower it 3/4, should be a fun work truck.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-02-2020, 05:55 PM   #2
cochino12
cochino12's Avatar
Re: I've got a couple new dually projects
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 04-02-2020, 06:12 PM   #3
SCOTI
SCOTI's Avatar
White CC cleaned up nice.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-02-2020, 11:05 PM   #4
Loco83
Loco83's Avatar
Loco83 is offline   Reply With Quote
Old 04-03-2020, 07:49 AM   #5
focusedontheprize
focusedontheprize's Avatar
The white C30 looks great, who did you go with for the 22s?
focusedontheprize is offline   Reply With Quote
Old 04-03-2020, 12:54 PM   #6
cochino12
cochino12's Avatar
I tried ordering from a couple of companies in AZ but had a hard time getting pricing... I ended up ordering from wheelsamillion in FL. They were very easy to deal with and had them shipped in just a couple days.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 04-05-2020, 09:29 AM   #7
Pontiac1976
Pontiac1976's Avatar
Vary Kool truck can't wait see it finnished
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-05-2020, 11:00 AM   #8
Nice trucks
Old 04-05-2020, 01:00 PM   #9
SCOTI
SCOTI's Avatar
Are these milled/faced like the "companies in AZ"?
How much gap between the sidewall & outer fender lip?
Stock dually Dana 70 rear?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-05-2020, 08:14 PM   #10
cochino12
cochino12's Avatar
same as the other guys flat face outer wheel. Not much room between fender and tire, about 1/4". Stock dana 70 and no mods to the inner or outer fenders
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 05-23-2020, 05:27 PM   #11
cochino12
cochino12's Avatar
Dump bed truck is running, lowered 3/4. Id like to go a little lower but dont think I want to spend the $$ for spindles. Cleaned up the wheels today, next up straightening up the interior, getting all of the lights working, building a headache rack
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 05-23-2020, 06:08 PM   #12
Ziegelsteinfaust
I love your trucks.
The red flatbed needs 22's too.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-23-2020, 06:31 PM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Really like the red single cab.
Keith
Convert to disc brakes.
Old 05-24-2020, 07:14 AM   #14
Old 05-24-2020, 04:12 PM   #15
farmall
farmall's Avatar
Like the red one. Id go with a 6 or 8" wood headboard, loose the pipes and get some Timpte mud flaps. https://store.timpte.com/product?object=9794
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 05-27-2020, 12:11 PM   #16
Pontiac1976
Really like the red 3/4ton very sharp.
