05-31-2019, 04:00 PM | #1 |
Old member
Rear disc brakes
I finally think I got the CPP rear disc brakes like they need to be after several years and many, many tries. I found a video that showed the guy putting the 9/16" wrench on the bolt that you turn counter clockwise to tighten up the pads with the nut on the backside of it. This keeps the shaft from going into the caliper and you can adjust the dang thing like it needs to be. I did this this morning with help from my daughter to bleed the brakes again also. The E brake will hold the truck still now on a hill! I even have a better pedal feel still not as good as with the drums but much better than it has been in several years!
Here is the video.
05-31-2019, 10:57 PM | #2 |
Re: Rear disc brakes
thank you
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
06-01-2019, 06:07 AM | #3 |
Old member
I have been fighting this problem for 2-3 years now and even CPP couldn't explain the right way to do it. I wished I had just bought the front big brake kit and left the rear alone.
On my daughters 68 truck that is what I plan to do.
08-23-2019, 01:10 PM | #4 |
Great Vid!
08-25-2019, 08:45 PM | #5 |
Sort of makes me happy I only bought front disc kit!
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
08-25-2019, 10:59 PM | #6 |
Old member
I'm going to buy the big brake kit for my daughters truck and leave the drums on back for sure!
