Old 01-08-2020, 11:59 PM   #1
1rippen6
Odd find, hatch latch with 4 mounting bolts
I was removing a hatch latch and realized it had 4 mounting bolts so I'm wondering if it was a year thing like maybe 69? I also noticed the rod had dimples in it for lack of better terminology. I removed the hatch from a single wall top but it's the only one I've ever seen with 4 mounting bolts. I've removed the mounting plates from the inside of the hatches before to replace and the ones with 3 mounting holes only have 3 nuts.
1rippen6 is offline   Reply With Quote
Old 01-09-2020, 04:28 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Odd find, hatch latch with 4 mounting bolts
Dwayne thanks for making time to post - that's really interesting. Any idea if that orange paint is OEM or if there is any white OEM paint underneath? I believe the inside portions of the hatch received paint for 69.
Old 01-10-2020, 10:04 AM   #3
1rippen6
I'm not sure, I'll take a closer look when I pull it back out. I think I sold the top it was on but will look at it also if it's still here.
Old 01-12-2020, 08:03 PM   #4
aotte1
That looks similar to a 1966 Suburban clam shell latch. Will post photo of it.
Les
aotte1 is offline   Reply With Quote
Old 01-12-2020, 08:16 PM   #5
aotte1
FYI
The 66’ Suburban barn door latch, photo below.
Dwayne, the 66’ pieces have some similar characteristics. What do 67 to 72’ Suburban latches look like?
Interesting question. 69 model year is a good thought, considering evolution of previous latches GM used.
Les
Old 01-12-2020, 10:08 PM   #6
1968k20
1968k20's Avatar
Looks like 67-72 suburban hatch latch
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 01-13-2020, 11:11 AM   #7
Jesse B.
My 1969 hatch latches have four bolts. It is possible it is the original hatch.
Jesse B. is offline   Reply With Quote
Old 01-13-2020, 12:12 PM   #8
1rippen6
Post some pictures when you get a chance.
Old 01-15-2020, 06:20 PM   #9
Jesse B.
Here is a pic of my latch. It is not just a three hole latch with an extra hole. The location of the holes are different.
Old 01-15-2020, 06:22 PM   #10
1rippen6
I didn't realize that good to know.
Old 01-23-2020, 07:45 PM   #11
1rippen6
So I pulled all my hatches out today and actually found a second one with 4 bolts.
Old 01-25-2020, 09:18 AM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Maybe a 69 thing? If that second one has factory paint other than white it would support a 69 MY piece.
Old 02-11-2020, 02:02 PM   #13
jlmerie
jlmerie's Avatar
On a slightly different tangent, I was looking at a pair of brackets that are used to cover the hatch latch bolt(s). One from each side of the hatch. While looking at them, I was shocked to see how different the size was from one to the other. I am virtually certain these were removed from the same hatch and were original at that time. Why one would be that much wider is a mystery to me. Trying to find other pictures of these "covers" I find that most of them are the same width, but a few are different. I tried to get a good picture of the open side, and there does not appear to be any obvious signs of cutting. Any ideas what is going on here?
James
jlmerie is offline   Reply With Quote
Old 02-11-2020, 07:12 PM   #14
1rippen6
As far as I know, they are all like that.
Old 02-11-2020, 07:15 PM   #15
1rippen6
It may have something to do with this. Just noticed the other day the top 2 holes are offset from side to side.
Old 02-11-2020, 10:56 PM   #16
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I wonder if the offset has something to do with the struts that span the handle to the latches - one sits higher than the other inside the hatch if I recall.
Old 02-11-2020, 11:52 PM   #17
1rippen6
If you look at post #11 the plate on the latch is on top on one side and at the bottom of the other side. Guessing that would position the latch plate in the middle of the catch.
