09-06-2017, 10:43 PM | #1 |
Leaf my truck alone!
Ok, I'm going a little crazy. I keep getting leaves popping out of my vents, or worse yet, stuck in the blower fan!
These are still last years stock, and this year's leaves are about to drop. Has anyone found a way to keep leaves out of these trucks? Thanks! Jim |
09-06-2017, 10:47 PM | #2 |
Re: Leaf my truck alone!
There are aftermarket trash guards that can be installed under the cowl. Also pull the side vents out in the cab and shove a vacuum cleaner flexible hose down through the hole to suck all the crap out
09-06-2017, 10:52 PM | #3 |
Thanks for the quick reply! I've dug in by hand, but the vacuum is a great idea, and ill see if I can find the trash guards.
Thanks again! Jim |
09-06-2017, 11:05 PM | #4 |
Here's a picture of the trash guards installed on my truck. Not only do they keep stuff out, they mask that ugly void below.
Jim |
09-07-2017, 12:18 AM | #5 |
i siliconed a piece of metal window screen on the underneath of my cowl vent. it works great and i just pass my air nozzle over it once in a while and its clean. i was going to use plastic screen but it wouldnt hold up in the sun.
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
09-07-2017, 12:27 AM | #6 |
20' Daredevil (Ret)
You can used almost anything to make a cowl screen. A few years ago my neighbors had new gutters put on their house. A piece of gutter guard ended up in my yard and nobody claimed it. It's powdercoated expanded steel and just big enough. I trimmed it to fit and it now lives under my cowl.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-07-2017, 04:27 PM | #7 | |
09-07-2017, 07:15 PM | #8 |
I used aluminum gutter guard glued in with construction adhesive.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
09-07-2017, 07:28 PM | #9 |
I vacume out what I can then stick a leaf blower in there.
09-07-2017, 08:42 PM | #10 |
How difficult is it to remove the cowl, mine looks like it's under several layers of paint.
72 White Cheyenne, The Ghost |
09-07-2017, 09:21 PM | #11 |
09-07-2017, 10:40 PM | #12 | |
The Older Generation
You forgot 4 sheet metal screws across the top up by the wiper transmissions... LockDoc
09-07-2017, 11:10 PM | #13 |
Wow, more great tips, that is what I needed to keep the rest of my sanity!
Great group on the forum, thanks! Jim |
09-08-2017, 02:44 PM | #14 | |
Check this place out also: Hotrodders.com I know some are over there also. |
09-08-2017, 03:03 PM | #15 |
I remember someone telling me they used normal screen material and just used small self tapping screws to hold it down... I might do that for a cheap setup.
09-08-2017, 03:10 PM | #16 |
Can somebody please explain how to remove the wiper arms ? Do you just tap them off ? Sure need to remove the cowl on my `69 truck , it's full of pine straw . THANKS !!
09-08-2017, 04:32 PM | #17 |
There should be a little tab under the head of the wiper you pull down with a screw driver and the wiper should work its way off. That never happens. Pull the tab down with the screw driver and then use the screw driver to help you pull up from under the head. Wear gloves so you don't slice your hands. hopefully that makes sense.
09-08-2017, 05:25 PM | #18 |
I am still pulling leaves out of my cab from the previous owner. It has been in the garage since I bought it with no trees within 50 yards...
Need to vacuum out my vents. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
09-09-2017, 10:43 AM | #19 |
THANKS for the reply chevylover . Didn't see a tab , but I'll take a closer look .
09-09-2017, 12:04 PM | #20 |
Screens are a great Idea. Think I'll be fabing one of those.
Once a year, I open the kick panel vents and cram a garden hose in the cowl to flush it out thoroughly. I also douche out the cab corners, rocker panels and the doors (Yes, this makes the interior wet). Let the water run 'till it runs clear. You might be amazed how much crap comes out, then let it set out and dry in the sun. I flush out all four fenders several times a year. Happy truck |
09-10-2017, 10:32 AM | #21 | |
https://store.snapon.com/Window-and-...l-P636287.aspx
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-10-2017, 02:52 PM | #22 |
Msgt USAF Ret
I'll add my pictures.
Removing the top cowl. This bolt is behind the door on each side. Don't forget the antenna. Remove the wipers and cowl screws. Got the cowl off.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
09-10-2017, 03:17 PM | #23 |
Msgt USAF Ret
More pictures of the leaf protection.
I used Aluminum mesh from a roll. I cut it to fit and painted the top green so the aluminum wouldn't show. Held into place with clothespins and popsicle sticks. I used black silicon gasket maker to glue it and hold it in. After it set I put it back on the truck.
09-10-2017, 04:01 PM | #24 |
VetteVet,
Thanks for taking the time to post the pictures.
09-11-2017, 05:12 AM | #25 |
THANKS for the replies , pics , and special tool info .
