Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-11-2006, 10:17 PM   #1
wolfthing2000
Rocker Panel replacement
I have the LMC catalog and Classic Industries catalogs and the rerplacement outer rockers sell for 20 bucks. Classic offers the OEM style and also one with a curve. I don't quite understand the diff.???? If LMC sells a decent part should I go with them???? What have you guys used for sources and which one is the easiest to deal with."?????
Thank you.
wolfthing2000 is offline   Reply With Quote
Old 03-11-2006, 10:47 PM   #2
GMC70c20
Re: Rocker Panel replacement
I personally would only buy panels from goodmark unless I could get a killer deal otherwise. From what i've found goodmark uses gms desine when they stamp panels so they tend to fit alot better, the better they fit the less work it will be.
GMC70c20 is offline   Reply With Quote
Old 03-11-2006, 10:50 PM   #3
wolfthing2000
Thanks. Is there a web site???
Old 03-11-2006, 10:59 PM   #4
wolfthing2000
I Googled and found Goodmark. 19.95.................same price as the rest.
I will order from Goodmark....
I am glad you mentioned them!
Thanks!
Old 03-20-2006, 12:07 AM   #5
BK
BK Built
BK's Avatar
I tried some other no-name brand rockers... didnt fit well at all. They were tweaked and i got mad and hit them with a sledge. Then i ordered inner and outer rockers from Goodmark. Fit awesome. Then got cab supports, inner and outer door bottoms, floor pans and they all fit very well. Goodmark = Great fit
BK is offline   Reply With Quote
Old 03-20-2006, 12:19 AM   #6
pjmoreland
pjmoreland's Avatar
I ordered some rockers from LMC once. The metal was super thin, and the fit was horrible. I ended up ordering some from www.gmcpauls.com (made by Triplus). The fit was great, and the metal was nice and thick.
pjmoreland is offline   Reply With Quote
Old 03-20-2006, 07:47 AM   #7
hchad18
hchad18's Avatar
I ordered my floor, rocker, kick panel, front pillar, cab corner, floor supports ect from LMC and all but one or two pieces were Triplus. If Triplus is a great fit I would hate to see what a bad one is. They didn't fit horrible but a little massaging was needed.
hchad18 is offline   Reply With Quote
Old 03-20-2006, 02:55 PM   #8
FnLow69
FnLow69's Avatar
i ordered mine from chevyduty.com and the fit good for me also got cab corners and floor pans they all fit good.
FnLow69 is offline   Reply With Quote
Old 03-22-2006, 03:44 PM   #9
49studebaker
49studebaker's Avatar
Experience tells me if it has a Goodmark label, it will most likely also have a triplus label. Goodmark gets their patch panels from overseas like most everyone else does. Chevy Duty is good(triplus also), but I've got the exact same parts from other vendors. With a little bit of modification they all fit.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 03-23-2006, 07:19 AM   #10
mbgmike
We pretty much all get are sheet metal parts from the same places.We sell TriPlus.You can still buy new oem rocker replacement panels from Gm for 67-72 chevys They run close to $90.00 each if you want to take that route. Installing them isn't really much easier or harder than aftermarket ones.We install the products we sell and don't have much problems with the reproduction ones.
Mike
Mikes Bump and Grind Garage
mbgmike is offline   Reply With Quote
Old 03-23-2006, 01:17 PM   #11
BigShoe24
True Addiction
BigShoe24's Avatar
I am using LMC, they worked fairly well. This is my first time, but I didn't have to much trouble, how easy could it be?
Also, can anyone tell me why my URL is not at the bottom of my post? I need some help, Thanks
BigShoe24 is offline   Reply With Quote
Old 03-23-2006, 02:36 PM   #12
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I have the Goodmark Rocker for 16.95 + shipping...
http://www.73-87chevytrucks.com/merc...ry_Code=6772CB
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
