02-04-2019, 01:55 PM | #1 |
BBC fan shroud
So in my 70 lwb I went from a sbc to a bbc and the fan shroud is way smaller. Does any one know where I can get a fan shroud for cheap? Lmc wants 160$ for the one for the 402. I jacked mine up by cutting it.
70 custom10 swb fleet side 454 th400 |
02-04-2019, 04:48 PM | #2 |
Re: BBC fan shroud
Pretty sure the Sb shroud is bigger then the big block. Normally you slide the engine crossmember up to the front 6 cylinder holes for a Big block.
02-04-2019, 09:49 PM | #3 |
Re: BBC fan shroud
I have both shrouds neither are for sale i will take some measurments and pics tomorrow if you like ....but i should say its the other way around i think th SBC shroud is smaller and you move the engine stands ( not the crossmember)to the forward holes in the frame on a IN6 to a SB not sure of the position on the BB got one of those also ill check that tomorrow hope Im correct on all this if Im wrong Im sure there are others with more knowledge than I
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 02-04-2019 at 09:50 PM. Reason: more |
02-04-2019, 09:58 PM | #4 |
Re: BBC fan shroud
The big block shroud has an opening that goes up higher than the SB shroud. The big block water pump is much higher in the chassis than the small block setup.
You might be able to cobble together something, but in the end I think you will wind up buying a big block shroud. You might get lucky and find a used one where somebody is parting out a truck or LS swapping.
02-05-2019, 01:09 PM | #5 |
Re: BBC fan shroud
They come up on the parts board every so often. The part # is 3924932, you might check Ebay
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-05-2019, 01:15 PM | #6 |
Re: BBC fan shroud
Here are some pictures. 69 396 and a 72 350.
02-05-2019, 02:56 PM | #7 |
Re: BBC fan shroud
Both the small block and big block use the same frame holes. The big block stands are bent back 1.25 or 1.5'' more than the small block.
