Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-23-2021, 04:43 PM   #1
KyFarm
KyFarm's Avatar
Battery Box ground
I'm really getting through the re-wire I'm working on ('69 K10, AAW kit) and getting things put back together but they didn't provide any materials or info on grounding.
I've done some research on here and think I can make a go of it but I do have a two questions:
There is a grounding location on the bottom of the battery box, can I run a wire from there to the spot of the core support where the right headlight ground wire goes to? or battery box to battery neg terminal
and
this kinda goes with the above, it is proper to use the same grounding location for more than one wire or is that a no-no?
Thanks for any help
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 01-23-2021, 06:14 PM   #2
LS short box
Re: Battery Box ground
I most likely over ground stuff but here's what I do on my LS swaps. LS computers love good grounds.
Battery to frame. Frame to engine in two places. Large diameter cable like 00 size. Frame to cab or body in two places. Smaller cable like 6 gauge? Then frame to radiator support. Smaller gauge like 10-12 gauge. Depending on your setup in the cab I weld a bolt to the fire wall that's long enough to hold all the grounds underneath the dash.
At the rear same thing. Lights grounded to the frame.
LS short box is offline   Reply With Quote
Old 01-23-2021, 07:18 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
In addition you might want to check this thread from the FAQS. Esp posts 2 and 4.
http://67-72chevytrucks.com/vboard/s...d.php?t=422234
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-24-2021, 09:19 AM   #4
KyFarm
KyFarm's Avatar
thanks for the help, exactly what I needed.
so, should a competent auto parts store be able to make custom ground cables?
Old 01-24-2021, 12:52 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Battery Box ground
May want to check these out.
https://falconerelectronics.com/buy-ground-straps/
A friend of mine gave me 2 rolls of this to use when I built the 68 pick up. It worked great.
http://nationwide-radio--amp-amp-amp...ng-25-ft-roll/
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-24-2021, 05:23 PM   #6
LS short box
You can get welding cable and ends at NAPA and make your own. Welding cable has really fine wires. Fine wires conduct better. NAPA has many different gauges of wire to choose from.
Make sure to clean off the metal really well where you attach the grounds.
