Old 06-30-2018, 12:16 PM   #1
70GMCer
70GMCer's Avatar
AC Hose Connectors
I'm to the point where I'm going to need to buy the AC hoses for my updated ac system in my 83.
I need to know what size fitting is needed where it connects to the dryer pipe as shown in the picture. (Has the red cap on the pipe)
I've done a google search and the sizes stated for the connectors say #6, #8, #10 & so on.
The only difference from the factory setup is I'll be using a Sanden 508 compressor using R134
The evap & condenser is of an OEM replacement.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-30-2018, 12:37 PM   #2
andyh1956
Re: AC Hose Connectors
Here's a link to a PDF I use a lot.
file:///C:/Users/Jonez/AppData/Local/Temp/Fittings.pdf
I started using the Eaton EZ Clip System in Afghanistan & have used them ever since
http://www.eaton.com/Eaton/ProductsS...clip/index.htm
The ATCO folks also have the Air O Crimp system, a little different than the Eaton but same principle.
andyh1956 is offline   Reply With Quote
Old 06-30-2018, 12:54 PM   #3
70GMCer
70GMCer's Avatar
Thanks for that link....but I still need to know the size of that suction line fitting..
1997 GMC Sierra Ext
1965 Mustang
Old 06-30-2018, 01:44 PM   #4
hatzie
Moderator
hatzie's Avatar
Your fittings PDF didn't upload. We can't get to the root drive on your system over the internet... or I hope we can't.
That's actually pretty slick. Eaton made up a system using Oetiker type clamps with a sheet metal locator bar to make sure you crimp the hose down on the O-rings in the Eaton fitting.
And I don't know what the suction fitting size is. If there's a local refrigeration outfit they may be able to tell you what the fitting type and size is by looking at the accumulator or the original 1983 hose end. No shame in cutting the old hose to liberate the connector for a comparison.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-30-2018, 02:40 PM   #5
andyh1956
Hey what do I know? I'm just an old mechanic, not a computer Wizard!
I just ride 'em, I don't know what makes 'em go!
Try this link here & scroll down some until you see fitting size designation Atco products
https://www.google.com/search?q=atco...firefox-b-1-ab
Old 06-30-2018, 07:43 PM   #6
100%Chevy
Well,if you were here in south Mississippi,I could probably match it up for you!
I make hoses and have a huge supply of parts.
Your best bet is to take it to your local a/c shop and they can fix you up.
Mike.
100%Chevy is offline   Reply With Quote
Old 06-30-2018, 11:33 PM   #7
SunSoaked
SunSoaked's Avatar
#8. You using beadlock or barbed fittings? I'm going thru this myself with my 85. I got to the point your at and realized my hose fittings don't match up to the factory components ( I got the same drier as you). Either go to a hydraulic/hose shop and have them make your " one of a kind hoses) or do like I did and bought the v/a evap kit so it's not all cobbled together.
SunSoaked is offline   Reply With Quote
Old 07-01-2018, 07:32 AM   #8
70GMCer
70GMCer's Avatar
Looks like that's what I'm going to have to do...is take it to a AC shop somewhere around where I live.....thanks for the advice though.....
1997 GMC Sierra Ext
1965 Mustang
Old 07-01-2018, 09:57 AM   #9
v30crewcab
v30crewcab's Avatar
https://coldhose.com/
they will custom build and crimp your hoses for you if you give then the length and info.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-01-2018, 09:59 AM   #10
v30crewcab
v30crewcab's Avatar
I just ordered a bunch of pieces from them for a cummins swap I'm doing. I can get the sizes for you in a bit.
71 longbed 5.3 4l80
Old 07-01-2018, 10:03 AM   #11
70GMCer
70GMCer's Avatar
..any help is appreciated
1997 GMC Sierra Ext
1965 Mustang
Old 07-01-2018, 10:25 AM   #12
70GMCer
70GMCer's Avatar
Here's another picture of the fitting in question...
1997 GMC Sierra Ext
1965 Mustang
Old 07-01-2018, 01:20 PM   #13
andyh1956
If that is measuring 1 1/16" or 27mm then that is 3/4" tube & corresponding hose size would be #14 hose.
Old 07-01-2018, 01:31 PM   #14
v30crewcab
v30crewcab's Avatar
Heres the list I bought. I am using a 87-88 dryer. not sure if its the same fitting as yours but it probably is. the 12-10 90 is what connects to the dryer.
71 longbed 5.3 4l80
Old 07-01-2018, 01:32 PM   #15
v30crewcab
v30crewcab's Avatar
not sure why its upside down.
71 longbed 5.3 4l80
Old 07-01-2018, 01:39 PM   #16
v30crewcab
v30crewcab's Avatar
the upper fitting
71 longbed 5.3 4l80
Old 07-02-2018, 07:06 AM   #17
70GMCer
70GMCer's Avatar
the upper fitting
That looks like what I need.
So, is that a #12 fitting?
1997 GMC Sierra Ext
1965 Mustang
Old 07-02-2018, 09:06 AM   #18
v30crewcab
v30crewcab's Avatar
yes
71 longbed 5.3 4l80
Old 07-02-2018, 09:07 AM   #19
70GMCer
70GMCer's Avatar
yes
Thanks...
1997 GMC Sierra Ext
1965 Mustang
Old 09-19-2018, 02:33 PM   #20
bigoilman
Mike.
Mike,
I'm local to you and may need some help sorting out the A/C on my LS swapped C30. Shoot me a PM when you get this if you don't mind.
Thanks,
Richard
bigoilman is offline   Reply With Quote
Old 09-19-2018, 07:29 PM   #21
100%Chevy
Originally Posted by bigoilman View Post
Mike,
Thanks,
Richard
Sent you a pm.
Mike.
