09-20-2019, 01:18 PM | #1 |
3RD brake light issue
Hi all, happy Friday.
I purchased an LED 3rd brake light from Robznob11 and installed it. WORKS GREAT WHEN STOPPING! only if the driver or passenger door is open. ??? wired it into the brake light switch white wire. 1970 c10 2wd. any suggestions? |
09-20-2019, 01:23 PM | #2 |
Re: 3RD brake light issue
Is it grounded though the door swiches? That's my only gess
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
09-20-2019, 01:24 PM | #3 |
If I read this right, for some reason its using the same ground as the courtesy lights. If so, when the doors are closed, there is no ground for the light - that is why. You have to ground the light separate from the courtesy light circuit.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
09-20-2019, 01:55 PM | #4 |
THANK YOU. I'll pull off the cargo / 3rd light and see where it is grounded and that sounds like you nailed it perfectly.
09-20-2019, 01:55 PM | #5 |
09-20-2019, 02:41 PM | #6 |
You could just drive with the doors open just a thought.
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
09-20-2019, 03:41 PM | #7 |
09-20-2019, 09:13 PM | #8 |
Did you replace the brake pedal switch to a 3 wire? You need a dedicated circuit going to the 3rd brake light.
09-20-2019, 09:43 PM | #9 |
09-20-2019, 09:43 PM | #10 |
Old member
I just installed mine a few weeks ago and I also had to change the ground wire to the back of the screws holding it in place.
My link on installing it. http://67-72chevytrucks.com/vboard/s...d.php?t=790874
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-21-2019, 05:04 PM | #11 |
[QUOTE=Andy4639;8596571][B][COLOR="Red"]I just installed mine a few weeks ago and I also had to change the ground wire to the back of the screws holding it in place.
FINALLY got around to changing the ground. I did what Andy4639 suggested and now i don't have to open the door when stopping to make the third brake light work. Thank you for your help fellas as usual. |
10-22-2019, 12:12 PM | #12 | |
[quote=elorenzof;8613605]
"Watch out Harold! Looks like we have a loony ahead of us getting his nerve up to jump out of his truck. This is the third time he has opened his door but decided to stop"
10-25-2019, 09:16 AM | #13 |
[quote=special-K;8614121]Haha too funny!
