Old 03-03-2017, 12:08 PM   #1
akatc
akatc's Avatar
Fuel cell return line question.
Hey guys, making progress on the LSX swap on Project Arrogant Bastard. But I ran into a question I cannot seem to find the answer. I'm doing a return style fuel system. The fuel cell I purchased has two fitting on the top of the tank. From all of the info I've read is I need a return line to the bottom of the tank to avoid aeration of the fuel. My issue is the two ports on the top of the tank should be a vent and return. But neither has a "drop tube" to the bottom of the tank. So if I added my return line it would just be dumping in the top of the fuel.
I've found one company that sells a kit you have to drill a hole and bolt in a drop tube. Any ideas?
akatc is offline   Reply With Quote
Old 03-03-2017, 12:25 PM   #2
PGSigns
PGSigns's Avatar
Re: Fuel cell return line question.
Are the fittings welded in? If not you can remove the filler assembly and remove the fitting and ad the tube. We did this on cells we ran with injected motors. Us a steel fitting and drill it for a 3/8 or 5/16" tube and silver solder or braze it in.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-03-2017, 01:11 PM   #3
akatc
akatc's Avatar
Jimmy
Yes they are welded in, They're an fittings so could just cap one of them.
Old 03-03-2017, 02:07 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
What are the two fittings at the bottom edge of the tank going to be used for?
Old 03-03-2017, 03:37 PM   #5
urmyboyblue
My tank has the same two bungs in it- one for vent and one for return. My tank also has a divider in the middle running across the tank with foam in the back section near the sump. This prevents aeration- have not had a problem with this design at all. So if your tank has the same divider and foam, I would not worry about it.
The bottom two fittings at the bottom are fuel pickups.
urmyboyblue is offline   Reply With Quote
Old 03-03-2017, 03:39 PM   #6
The Rocknrod
Moderator
You need two fuel pickups? And two returns? Go easy now, i'm still carbureted.
Old 03-03-2017, 04:40 PM   #7
akatc
akatc's Avatar
Ill check it out this afternoon. I know it has the foam inside but I dont think it has the divider.
Old 03-03-2017, 05:32 PM   #8
urmyboyblue
Mine pulls fuel from both for the EFI and the N2O.
Old 03-03-2017, 07:04 PM   #9
PGSigns
PGSigns's Avatar
If it has foam in it you will be fine.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-04-2017, 10:48 AM   #10
vin63
It's Better With Nitro
vin63's Avatar
I wouldn't worry about it since the vent and return bulkhead fittings are on the opposite side of the fuel pickup and it has baffling foam (I'm not a big fan of the baffling foam especially for EFI applications) . I would be more concerned with the size of the vent and return fittings as they relate to the volume of the fuel supply of your system.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-04-2017, 12:22 PM   #11
akatc
akatc's Avatar
Why are you not a fan of foam? Is it because it can break down over time? I've never had any experience with it so I have no clue. The fitting are -10an seem to be plenty big for my application.
Thanks for all the replys.
Old 03-04-2017, 02:15 PM   #12
vin63
vin63's Avatar
It's hit or miss with the quality of the baffling foam, or dislodged particles created during production/installation waiting to be carried off by fluid. I have worked on many drag cars that had fuel delivery failures from foam particles clogging the pump and/or regulator(s). I just didn't take the risk and removed the foam from my fuel cell in my Super Gas drag car. If you keep the foam, run a good filter that is easily inspected and cleaned or element replaced between the fuel pick up of the cell and the pump. Is the 10AN fitting the fuel pick ups, or the vent and return ports?
cell, fuel, gas
