01-28-2020, 02:33 AM | #1 |
Always on the hunt...
F/S GM NOS 4wd Transfer Case Mount Bushings
4wd four piece NOS transfer case side support mount bushing set, you will receive two upper (thin) and two lower (thick) rubber cushions. $130. shipped via USPS. Will accept paypal, check or money orderl as forms of payment, if using paypal option add 3%. Thanks for looking, Mel
***Qty. Six NOS 4 piece T/C rubber bushing-cushion setups Sold/Shipped*** . Last edited by Classic Bowties; 10-09-2020 at 08:36 PM. Reason: updated availability |
01-28-2020, 06:17 AM | #2 |
“On The Hunt”
Re: F/S GM NOS 4wd Transfer Case Mount Bushings
Mel, If it’s for a 205 transfer case I’ll take it
01-28-2020, 07:01 PM | #3 |
Hey Nic, yes these are correct for all 67-72 K/5-10-1500-20-2500 4wd's with both 3/4 speed manual and TH350/auto transmissions, the transfer case mounted support brackets themselves had differences over the years (see below manual pics) but the rubber bushings/cushions were the same. We currently have a few of these four piece NOS t/c rubber bushing setups available/on hand if you need more than one set, also if needed we can supply you with this pair of NOS t/c bushing steel spacers/sleeves (see below red arrows) for $35. Let me know and we'll get your combined total figured up on these and the NOS grill emblem from the other thread, Mel
01-28-2020, 07:06 PM | #4 |
More pics...
01-29-2020, 11:44 PM | #5 |
Funds received for one 4 pc. set of NOS t/c mount bushings and the added pair of NOS steel t/c bushing spacer sleeves, let me know when you're ready to finalize this shipment/order and we'll get it packed and headed your way. Thanks again on the multiple purchases, Mel
02-12-2020, 04:29 AM | #6 |
Just updated top post, we have two 4 pc. NOS t/c cushion-bushing setups remaining/on hand. Mel
02-12-2020, 10:46 AM | #7 |
I will take a 4 piece set and 2 steel bushings.
02-12-2020, 10:06 PM | #8 |
02-13-2020, 12:45 AM | #9 |
Active Member
Do you have any bushings and and spacers left ?
02-14-2020, 01:19 AM | #10 |
Funds received on the NOS transfer case rubber bushing & steel spacer setup, your package went out via USPS first class on Thu. 02/13 and the expected delivery date is Tue. 02/18. Thanks again and let me know if we can help with any other 67-72 parts needs, Mel
02-14-2020, 01:36 AM | #11 |
02-15-2020, 03:33 AM | #12 |
The transfer case rubber bushings and steel spacers have been packed/shipped with your items from the other NOS parts f/s thread, the package went out via USPS priority on Fri. 02/14 and the expected delivery day is Tue. 02/18. Thanks again and let me know if we can help with any other 67-72 parts needs, Mel
02-28-2020, 01:27 AM | #13 |
The NOS t/c rubber bushings and steel spacer sleeves are under way, your multi-piece NOS parts order went out via USPS priority on Thu. 02/27 and the expected delivery date is this Sat. 02/29. Thanks again and let me know if we can help with any other 67-72 parts needs, Mel
02-28-2020, 02:46 AM | #14 |
I'd better get a set too.
02-28-2020, 02:15 PM | #15 |
02-28-2020, 03:01 PM | #16 |
Rubber bushings for the transfer case .I looked at my old steel sleeves this A.M and think they will be ok.
02-28-2020, 03:48 PM | #17 |
02-28-2020, 04:27 PM | #18 |
Do you have another set of upper and lower cushions?
02-28-2020, 04:28 PM | #19 |
PayPal sent.
02-28-2020, 05:42 PM | #20 |
02-28-2020, 06:48 PM | #21 |
I'm in no hurry, so I will mail you a check.
02-28-2020, 08:09 PM | #22 |
02-29-2020, 12:31 AM | #23 |
02-29-2020, 09:21 AM | #24 |
HI Mel,
I'll take a 4 piece set of rubber mounts. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
02-29-2020, 09:13 PM | #25 |
I went ahead and sent PP for mine.
