07-12-2019, 10:11 PM | #1 |
Rear Axle Identification/Ratio
When I bought my truck ('51 3100 5-window) in 2016 all indications were that at some point someone moved over a bunch of parts from an early or mid-60's Impala. It came with an Impala steering wheel which was the biggest giveaway, plus the aluminum Powerglide transmission, and all wheels had been converted to 5-lug Chevy, 5x4.75. That, and the owner told me it once had a 327 in it.
Ever since, I've wondered about the rear axle. Either the entire axle was swapped out, or the Impala's 5x4.75 splines were slid into the original housing. My bet is that it is most likely the former. So I have tried to identify it, and what possible gear ratio it is. I have 18" rear wheels with 255-40-18 tires. I put a 327 into it along with the Powerglide. I took it on the freeway first time about 10 days ago. It runs about 2,000 rpm at 40mph and 3,000 rpm at 60mph, which sounds like the motor wants to implode. I found a stamp on the rear of the housing, a "B" and a code, 3707306. There's a tag next to the GM stamp but it's unreadable. I might try again to see if I can get something from this tag. Running 3707306 on Google I get a bunch of car websites like Tri-Five Chevys, who claim that number is a mid-50's stamp, and the "B" indicates it was made in Buffalo. None of this really jives with idea that this would have come from a 64 Impala, but we're close. Also, I can't determine from any of this what the gear ratio is. Based on driving characteristics, I'd think this may be as low as a 3.70 ratio or as high as a 4.11 ratio, but most likely a 3.90 ratio. Can anyone help me identify this axle? Can we at least say for certain this is not the factory original 51 3100 truck axle? |
07-12-2019, 10:40 PM | #2 |
Re: Rear Axle Identification/Ratio
According to Summit Racing, it looks like I'm likely running a 3.90 or 4.11 ratio rear, according to this chart on their website. My 18" wheel and tire combo are approximately 28 inches in total diameter, so I'm seeing 2808 and 2952 as my rpm ratios at 60mph.
07-13-2019, 01:40 AM | #3 |
255/40-18 should be a 26in tall tire.....not 28 ...although tire sizes arnt always what they say they are
a 3.90 gear and 26 in tire and pg ratio of 1:1 would give you around 3024rpm at 60mph i use this to determine rpms... http://www.csgnetwork.com/multirpmcalc.html and this for tire sizes https://tiresize.com/chart/ that could possibly be a ratio tag on the diff bolt
07-13-2019, 01:53 AM | #4 |
that 3707306 number keeps showing a 55-56-57 rear axle
should be a number beside the GM ...under that tag remember..a lot can happen in over 60yrs if you really cleaned up the 3rd member you may find some stamped numbers on it
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-13-2019 at 02:08 AM. |
07-13-2019, 07:12 PM | #5 |
I suppose it really could be a 55-57 axle. No clue on ratio though. But I will be doing more cleanup on the axle (I plan to paint it) so like you said maybe I'll find some more numbers there.
07-13-2019, 07:17 PM | #6 | |
07-16-2019, 12:57 PM | #7 |
if it is a 55-57 chevy rearend be aware that those years are all single year bearing (axle) and back in the 80's I had one in a 34 chevy coupe. the bearings were difficult to find then. so I would find a newer axle if I were you. Also beware of 8"and9" ford axles. they are fusion welded at the axle/flange joint and weak, when that weld lets go bad things happen. I have a 8" rear in my 34 chevy (replaced the 57 rear) the left flange sheared of at 20 mph, the wheel and drum tore the left rear fender off the car ad bet up the body pretty badly. Since I heard of a 37 ford that had that happen at highway speed, car turned left and rolled. When I talked to the guys at Strange Engineering, he said yes they are weak, (all of them) and they will fail with NO WARNING at all. So know both of my cars, the 34 cpoupe and my 35 chevy sedan both have 8" rears with Strange axles in them. So good luck with your build.
07-17-2019, 01:41 PM | #8 | |
