Old 08-28-2007, 07:14 PM   #1
'68 longbed
'68 longbed's Avatar
removing stock balljoints
i'm fixin' to freshen up the front end, and I'm thinking ball joints are a priority. I've done the air chisel approach before and seems to butcher the a-arms a bit. drill bits don't seem to quite handle the job either..
anyone have a good trick for removing the rivets?
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. "
'68 longbed is offline   Reply With Quote
Old 08-28-2007, 07:24 PM   #2
scrapmetalart
Junior Member
Re: removing stock balljoints
your friend the 4" grinder. just be careful & grind the heads off...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 08-28-2007, 07:41 PM   #3
cdowns
cdowns's Avatar
i like to use my 3" cutoff tool its quite a bit quicker and easier to get in with than a grinder
Old 08-28-2007, 07:58 PM   #4
mvfd70
mvfd70's Avatar
I agree with the grinder. Grind the heads down flat, then take a punch and hammer and drive the rivets out.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 08-28-2007, 09:11 PM   #5
'68 longbed
thanks all, I wasn't looking forward to the chisel again!
Old 08-28-2007, 09:26 PM   #6
rick0312
rick0312's Avatar
grinding worked for me!
rick0312 is offline   Reply With Quote
Old 08-28-2007, 09:35 PM   #7
OJOE
Crew Cut
OJOE's Avatar
that will work on the upper ball joints. do you know how to replace the lower ?
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 08-28-2007, 10:01 PM   #8
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Ball joint press, looks like a big C clamp.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-28-2007, 10:30 PM   #9
rick0312
rick0312's Avatar
i was able to nock the lower ball joints out with a large socket and BFH. I then went to autozone and purcahsed there bal joint press and then pressed the lowers in with no pproblem! If you didn't know.... Autozone has a tool lending program... you essentially purchase the tool and then return it for a full refund with no questions asked!
Old 08-28-2007, 11:19 PM   #10
hemihead
hemihead's Avatar
Lower ball joints - remove lower a-arm and take to a shop. It is quick and easy with a hydraulic press and they can also press the new ones in at the same time. They can also let you know if the lower b-jt goes in to easy....this would indicate the hole for the ball joint is worn....found this on one of my '67's I worked on. Required a trip to the junk yard for a new lower a-arm.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
Old 08-28-2007, 11:22 PM   #11
67ChevyRedneck
67ChevyRedneck's Avatar
I've got their harmonic balancer install/removal tool right now, it's a cool deal.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
