Old 12-22-2014, 01:15 AM   #1
'68 Newtricks
'68 Newtricks's Avatar
Trouble with aftermarket tailgate or handle.
Hey folks, just hoping for a little help or a sharp eye.
I am running a full aftermarket bed from Classic Industries. (a mix of OER and TriPlus) Today I tried installing the tailgate handle inside the gate. It goes in but doesn't function. When I pull up on the handle, it hits the sheet metal right away. Two things could be wrong.
1) Handle is made wrong. The ratio (or pull arch) is off. It needs to swing out farther before going up.
2) Holes in tailgate for the handle are not down far enough. I think this might be it, but not sure. If the handle was ~3/4" lower, I think the arm of the handle will miss the sheet metal.
I've only got a picture of the holes right now Do they look right? See the one dimple that bleeds into the sheet metal bend? If that was a full dimple, it just might work. Dunno, really bums me out.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 12-22-2014, 06:31 AM   #2
merlin3
Re: Trouble with aftermarket tailgate or handle.
i tried to install a Triplus tailgate,handle and hardware from LMC on my 72,could not get the handle to work just like you described ,could not get the gate to line up either very poor quality.
merlin3 is offline   Reply With Quote
Old 12-22-2014, 10:09 AM   #3
FlameOut
Not what I wanted to hear. I bought my tailgate and hardware from LMC. I'm not even close to being ready to install it. Nice to know I'm in for more headaches
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 12-22-2014, 10:12 AM   #4
Kennuck
Kennuck's Avatar
Mine is from Woodall handle works fine. Here is a pic of the handle hole location. Hope it helps.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 12-22-2014, 10:35 AM   #5
bbcmudtruck
I bought all of my hardware as well as handle from LMC and it works just fine. The tailgate came from brothers.
bbcmudtruck is offline   Reply With Quote
Old 12-22-2014, 12:41 PM   #6
'68 Newtricks
Can I get a picture of the handle installed? Just wondering what it should look like inside the gate. Thanks!
'68 C10 SWB
'85 K30 Blazer
Old 02-28-2015, 09:11 PM   #7
Lanman1972
Lanman1972's Avatar
I have just run into the same problem with my tailgate. Did moving the holes down work? My parts are from GMCPauls. Thanks
Lanman1972 is offline   Reply With Quote
Old 02-28-2015, 09:47 PM   #8
'68 Newtricks
Haven't been able to fix this. Moving the holes is not possible because they are raised inside.
ClassicIndustries has been notified about the problem, they tested another handle and gate they had and confirmed the problem. But even after 2-3 calls they still don't have an answer for me, as to which is causing the issue. So my crap is still crap and I'm on the hunt for a factory gate.
'68 C10 SWB
'85 K30 Blazer
Old 02-28-2015, 10:03 PM   #9
Lanman1972
Lanman1972's Avatar
Not what I wanted to hear. I have mine painted (Should have assembled first). I will let you know if a solution is found. I'll be calling GMCPauls on Monday. Thanks.
Old 03-01-2015, 08:58 AM   #10
88fordf150
88fordf150's Avatar
Just a thought, can you put shims behind the handle to bring it out a little further?
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 03-01-2015, 09:15 AM   #11
john@thepier
john@thepier's Avatar
The aftermarket handles are junk, find a oem and install it. That is what I had to do, my aftermarket was from GMC Pauls and he confirmed they were all junk.
john@thepier is offline   Reply With Quote
Old 03-01-2015, 10:10 AM   #12
merlin3
88fordf150 i could not shim the handle because then it would hit the inside of outer skin of gate.my handle was also crooked after mounting and if i tried to use it the handle would spread apart and not pull the rods to the latches.i have never seen such junk,very disgusted.
Old 03-01-2015, 11:55 AM   #13
Ohio mike
I had the same problem and thought it was the tailgate. I bolted my old factory handle in and solved problem. The aftermarket handle hinges in wrong spot. JUNK.
Ohio mike is offline   Reply With Quote
Old 03-01-2015, 05:41 PM   #14
Lanman1972
Lanman1972's Avatar
I have my original handle and will try it tomorrow. Frustrating when you buy parts from One place and they don't fit, especially from recommended suppliers.
Old 03-02-2015, 09:06 PM   #15
'68 Newtricks
There isn't a weekend that goes by without regretting selling my tailgate with my longbed. It wasn't straight or pretty, but it worked dammit. Now I'm left with nothing
'68 C10 SWB
'85 K30 Blazer
Old 03-02-2015, 09:18 PM   #16
Lanman1972
Lanman1972's Avatar
Took my rusty crusty handle with me today and put it on the new tailgate, works perfect. Buyer beware with all the aftermarket stuff. Just seems that the recommended vendors on this site would know they are selling junk, and maybe they do. When you buy a complete package it should fit and function.
