05-24-2011, 10:15 PM | #1 |
door wont open
welll i put my door back on tonight and i shut it after fiddling with it for a while and........
Now it wont open, what did i do to deserve this???? lol any advice at all? can get that sucker open. i must just suck at this.
1968 Chevy short bed restoration/ build/ put back together/ whichever you wanna call it! I shall call it :"Rusty Tomato": its in the works " Anything free is worth saving up for " " If you dont know where to start, go back to the beginning " |
05-24-2011, 10:47 PM | #2 |
Re: door wont open
Might need a bit more info to help you out. Why you had the door off? Do you have the interior door panel removed? Can you tell if the rod that activates the inside release is working? Is the exterior handle button stuck? Was the door working right before it was removed?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
05-26-2011, 12:42 AM | #3 | |
Re: door wont open
05-26-2011, 10:14 PM | #4 |
Re: door wont open
If you put new weatherstrip on you might have to push in on the latch side just under the handle while u try to open it.
67 GMC SW 383 stroker/TH350 w/ 4.56 gears - under construction 04 GMC 1/2ton daily 07 GMC Acadia wifes daily |
05-26-2011, 11:40 PM | #5 |
Re: door wont open
ok in order to fix it you will need to take door panel off and try to manualy open it any way you can.
05-28-2011, 09:59 AM | #6 |
Re: door wont open
thanks guys ill try and figure it out
