06-24-2018, 06:38 PM | #1 |
Help Installing New Ignition Switch
what am I missing? Feeling real dumb here, have done this on other old vehicles, but cannot figure out my problem here.
I remember only taking-off the small bezel on my '67 Chevy C20. But now cannot get it to go together in my fresh dash. Even got a spacer used on 68 to 72's and no luck. (In picture with old switch.) Its like there is something missing to go behind dash, but my old bezel screwed into the dash, so what kept it from coming thru dash. Maybe the heat today has my head messed-up, but I cannot figure-out this simple delima. Its an AWW (American Auto Wire) upgrade kit, but old switch and new look the same. DJ |
06-24-2018, 06:54 PM | #2 |
Re: Help Installing New Ignition Switch
Loc Doc should be stopping by with pictures shortly...
He always does! Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
06-24-2018, 07:07 PM | #3 |
That would help - pictures a thousand words. I'm sure its something truly simple I'm missing, but just can't figure this one.
06-24-2018, 07:35 PM | #4 |
I think spacer goes behind dash. But Lockdoc will know for sure
06-24-2018, 08:00 PM | #5 |
blood type; Retumbo
Bottom pic, part on right goes on part on left. Stuff in from back of dash, install center part, then install lock cylinder
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
06-24-2018, 08:15 PM | #6 |
Tried. Spacer I have (catalog says for 68 & up, not 67,) leaves NO threads to screw bezel for 67 on to switch.
06-24-2018, 08:21 PM | #7 |
blood type; Retumbo
That's because 67 is flat dash while 68-up the switch is recessed.
It's time to do some after factory modifications to your spacer or source the correct parts
06-24-2018, 08:40 PM | #8 |
Todd Rusk hooked me up with this (separate correspondence):
https://www.cooperrestorations.com/p...nition-spacer/ Used only one year, like the shorter bezel. 0849-215 This ignition spacer fits: 1967 Chevrolet Pickup Truck and Suburban 1967 GMC Pickup Truck and Suburban Measurement 1.5x1x1 |
06-24-2018, 08:44 PM | #9 |
I assume the flat spot goes UP on switch?
06-24-2018, 10:29 PM | #10 |
The Older Generation
You have the wrong spacer. Here is a picture of the '67 only spacer. There is someone on here selling a reproduction of it. http://67-72chevytrucks.com/vboard/s...d.php?t=747570 The spacer indexes the switch in the correct position. Just make sure the key is vertical. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 06-24-2018 at 10:37 PM. |
06-25-2018, 07:15 AM | #11 |
Thank you Lock Doc. It figures 67 was different. I spent a lot of time trying to figure that out & left scratching my head frustrated. Thanks again.
DJ |
06-25-2018, 09:58 AM | #12 | |
No problem. The three small tabs you see on the face of the spacer (first picture) fit into the notches in the dash. Also be sure the bezel is started straight, the threads are pretty fine and it is easy to get them cross threaded. It should screw on pretty easy, you shouldn't have to force it. LockDoc
06-25-2018, 03:10 PM | #13 |
Thank you again Lock Doc; great feedback and advice.
DJ |
06-29-2018, 06:59 PM | #14 |
Yes it makes ALL the difference when you have the right parts!
For the life of me I cannot remember taking off that short adapter or if so where it got put? I do remember taking the old switch out because the whole wire harness and fuze panel were GONE (fuzes rusted in place - amazed I could drive it). Thank you all for your feedback. DJ |
06-30-2018, 09:11 AM | #15 | |
Good deal. Glad you got it all sorted out. LockDoc
07-03-2018, 08:45 PM | #16 |
Just a follow-up.
Pictures show the ignition switch flat spot goes to bottom toward back of dash and labels on contacts can be read right side up to correctly get the key vertical when done. Just wanted to clarify that for any future readers. |
02-01-2021, 07:04 PM | #17 |
Has anyone ever had a problem with the key not coming out of the lock cylinder once it’s installed in dash? I’m not sure what I’m doing wrong but key won’t pull out when turned to off position..
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E I call it Bruce Banner.. |
02-01-2021, 07:08 PM | #18 |
Never mind. I re read thread and I had it upside down. Thank you.
02-01-2021, 09:05 PM | #19 | |
Glad you got it figured out. They can be a pain sometimes. LockDoc
02-02-2021, 08:39 AM | #20 | |
02-02-2021, 10:03 AM | #21 | |
Unfortunately that's not the parts fault. If you could see my shop you would know why.... LockDoc
