01-26-2020, 05:46 AM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Cab weight?? 1 ton hoist??
Will a 1 ton hoist lift a '69 cab and long bed?? Separate of course. 1 ton mark is with the boom all the way in. And I think 1/4 ton fully extended. Thanks.
01-26-2020, 06:38 AM | #2 |
Re: Cab weight?? 1 ton hoist??
The hoist will work fine . The cab I moved was bare. The only hard part was finding the balance point. I took the short step off with it too but couldn't find my pics. Somebody made a bracket out of wood that bolts to your hoist would make it easier. I just strapped a landscape timber to the hoist and notched out to fit the pinch weld area on the door opening.
01-26-2020, 10:21 AM | #3 |
Yes what old school said
Did the same except I put a heavy screw in the center of the board and drilled a matching hole in the nose of the lift to keep it from sliding Make sure the floor is clean you don't want any sudden stops You can do it yourself but a second person never hurts Good luck and be safe |
01-26-2020, 10:40 AM | #4 |
I move them all the time with 2 - 2x6's with the hoist sandwhiched in between and a long bolt to hold it all together at the front of the door opening works for me . don't get under it .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
