11-17-2007, 10:14 PM | #1 |
HERE.......Somewhere
the ignition started to smoke a little bit
it started today when I parked the truck at my job and switched it off and it started to smoke a little bit so why the heck did it smoke
I hope it aint somoking old mary jane
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! Last edited by 70' GMC; 11-17-2007 at 10:15 PM. |
11-17-2007, 10:20 PM | #2 |
Re: the ignition started to smoke a little bit
Do you have an electronic ignition?
I do, and once the wires coming out the side of my dizzy had gotten old, the insulationing became brittle, then I smoked the control module in it. Quick trip to A-Z and $14 and I was back on the road.
72 Chevy C-10 Custom LWB 383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb. Hooker Comp Headers w/ X-Pipe and 2.25 duals TKO-500 & 3.08:1 rear I Love HEMI's, they're soft & chewy! |
11-17-2007, 10:32 PM | #3 |
will it hurt it or will it give me problems or both
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
11-17-2007, 11:02 PM | #4 |
Fortunately, mine happened in my driveway!
Does yours run now? You said the ignition smoked, did you see the source? If not I'd pop the dizzy cover and look. My typical luck would be it would quit half way to work when it's raining.
11-17-2007, 11:03 PM | #5 |
Do you have an electronic (HEI) distributer?
11-18-2007, 06:12 AM | #6 |
its all about the +6 inches
i think he's talking ignition switch.
These switches are known for this. Go to napa and get some dielectric grease. You can byt a tube, or for just a buck or so they should have the one time use packet. Lay down with a light looking up at the bavck of the ignition switch, You'll nee what needs to be done to unplug it. once you have it off of there, look at the connection, you'll probably find one kinda melted. If it is just a little melted, then just put the grease stuff into all the femail sides of the connection (harness side) and it should be good. If it looks pretty bad, then you'll need to replace the plug. |
11-18-2007, 06:22 AM | #7 |
is there a how to or something
11-18-2007, 06:32 AM | #8 |
yeah, post #6
11-18-2007, 07:18 AM | #9 |
To piggy back on to #6, if the plug is "a little melted", get a new plug. You can get a new plug from one of the many suppliers that support this site.
Once you have the new plug in hand, you can remove the wires from the old one with a little flat blade screwdriver. You need to push the wire in from the back of the plug, depress the little tab on the metal contact, and pull the wire out of the plug. If the wire looks good just plug it in the correct hole on the new plug. If the wire is fried, I'd cut it back to where it is good again and make a good soldered connection with a shrink wrap cover over it. I repaired my ignition switch a few years ago like above and never had another problem.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-18-2007, 09:10 AM | #10 |
11-18-2007, 09:25 AM | #11 |
Junior Member
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
11-18-2007, 09:27 AM | #12 |
Please make it stop Daddy! It Burns! My brain is melting! Make it Stop!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
11-18-2007, 09:49 AM | #13 |
11-18-2007, 12:51 PM | #14 |
Nothing to see here.....
deja vu...... in a bad way.
11-18-2007, 02:56 PM | #15 |
11-18-2007, 11:34 PM | #16 |
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
11-18-2007, 11:40 PM | #17 |
well at least it aint hit another one them thar poles I tell ya what
11-18-2007, 11:42 PM | #18 | |
11-18-2007, 11:46 PM | #19 |
yeah, it should be the same.
11-18-2007, 11:58 PM | #20 |
If it's not the same, it's different.
11-19-2007, 07:17 AM | #21 |
Ease up guys.Fun is fun,but...
11-21-2007, 06:42 AM | #22 |
it done it last night and I got under the dash and was watching it crank up and I seen light and smoke come out between the black and silver piece. the black piece was plastic and the silver piece was metal or gray in color.
11-21-2007, 07:17 AM | #23 |
If this was my truck, and I cared about it, I'd disconnect the battery until I got myself a new plug AND switch installed.
11-21-2007, 01:08 PM | #24 |
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
11-21-2007, 09:28 PM | #25 |
so what is the black and silver piece called?
