12-11-2015, 06:32 PM | #1 |
89 s-10 2.5 distributor ?
I am trying to get a truck running for a friend of mine. 89 S-10 2.5. The distributor was removed. I stabbed it with #1 cyl at TDC, rotor pointing at #1 terminal. The injector will not spray fuel . If you wiggle the black/red wire into the distributor it will pulse the injector. I suspect its bad wiring/sensor inside the distributor...I will try another distributor. Also, compression is 145-150 on all cylinders... My question is : can the distributor can be installed using any terminal as #1 or is there a certain orientation of the distributor ? I really don't want to pull the timing cover to check for timing marks just yet
72 C20 Longbed 05 1500 Z71 |
12-11-2015, 11:50 PM | #2 |
Re: 89 s-10 2.5 distributor ?
As long as the #1 piston is at TDC on the compression stroke, you can make whatever terminal the rotor is pointing at when you drop it in number 1.
12-12-2015, 02:51 AM | #3 | |
I thought so.. I guess I need to do some more work Thanks !
12-13-2015, 04:39 PM | #4 | |
12-15-2015, 12:03 AM | #5 | |
I will as soon as I go back over there on Friday ...its a 45 minute drive I do have another question.. I removed the distributor..It seems there is no slot for the distributor to line up and drive the oil pump ...Is this not like the old SBC ? Or is something broken ? Thanks
12-28-2015, 09:20 PM | #6 |
Yes, it should have a flat on the bottom to drive the oil pump.
