Old 01-20-2021, 05:48 PM   #26
jwhotrod
Re: Going to need a new radiator.
the point was if you put a hole in a vertical flow radiator it will stop working and overheat immediately. whereas a horizontal flow radiator with a hole in the upper part of the core just may get you home. so like i said GM,Ford,Mercedes and all the rest went to horizontal radiators, it wasnt because of cost, it was because of airconditioning bigger motors and better efficiency.
jwhotrod is offline   Reply With Quote
Old 01-22-2021, 02:01 AM   #27
washington blue
Thanks for all the information guys I appreciate it all. After lots of consideration I have decided to order a "Desert Cooler" 4 core brass copper and steel radiator. I ordered it from "Chevy truck Classic Parts". Thanks to "Ogre", you are a powerful salesman, lol. Norm
washington blue is offline   Reply With Quote
Old 01-22-2021, 08:42 AM   #28
my56chevytruck
my56chevytruck's Avatar
Check out Auto City Classics. Bought mine to cool a BBC
100% Aluminum, 100% Welded Radiator- Lifetime Warranty
New aluminum, direct bolt-in radiator. It has a built-in automatic transmission cooler with 1 1/2" center inlet and 1 3/4" right lower outlet. This is stamped with welded construction, no epoxy.
Comes with 2600 CFM fan and shroud.
Has dual 1 1/8" high flow tubes, double the cpacity for stock 2-row, 33% more capacity then 3-row 1/2".
Core size: 17 3/4" wide, 20 3/4" tall, 2 1/2" thick
Overall size (widest point): 22 1/2" wide, 26 3/4" tall, 3" thick
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
