Old 02-05-2021, 11:24 AM   #26
sick472
sick472's Avatar
Re: Venting....
Barring any real small pin hole leak in the tank, I would double check the sending unit seal.
My 85 smelled like gas (tanks under the bed) for a few years due to a pin hole leak that was not bad enough to drip, but enough to wick out and vaporize. The cab wasn't smelly, just the walk around areas. It finally rusted through enough to drip to the ground...AH HA! found the stink.
I assume that the vent line you have run up and back down the cab corner exits the cab somewhere? If so, you could run an extended piece of hose from that out far away from under the cab for a test. Let it set like that overnight/for a day and see if the cab smells better. That could prove the need for a canister or not. Vapors get vented away from the truck and have no way to sneak back in.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-05-2021, 12:52 PM   #27
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Venting....
Yea this was going to be my next step. I think Ill use some old hard line and run it in the rear frame rails to get it away from the cab. For now anyway and see how it does. Yea it's just under the cab on passenger side now.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
