Old 11-18-2020, 11:54 PM   #1
Lokin4AReason
Lokin4AReason's Avatar
Gas tank relocation ( fleetside )
Hello all
I have been viewing thread(s) on here for some time now
Seen some great idea(s) but something still feels like its missing . . .
Looking to relocate my tank to the rear but dont want it to not show past the rear bumper
Also see some modifications at where the tank was installed almost by the back of the cab underneath and by the trailing arm support using a 65/ 66 mustang tank .
Does any one have any insight or foto(s) of current or past mods that were done in relocating the tank ?
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 11-19-2020, 12:04 AM   #2
AcampoDave
AcampoDave's Avatar
Re: Gas tank relocation ( fleetside )
I too wanted a rear tank that didn't show....so I started this thread http://67-72chevytrucks.com/vboard/s...d.php?t=621177 and I found it.
AcampoDave is offline   Reply With Quote
Old 11-19-2020, 02:32 AM   #3
Lokin4AReason
Noticed as well , interchanging jeep components is being used a bit on these older model c10(s) . . .
Old 11-19-2020, 03:28 AM   #4
pdxhall
pdxhall's Avatar
Here's nine. Early mustang tank I mounted between the frame rails
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-19-2020, 05:23 PM   #5
1966c10shrtbd
1966c10shrtbd's Avatar
1966c10shrtbd is offline   Reply With Quote
Old 11-20-2020, 05:29 PM   #6
Lokin4AReason
Any foto(s) of the plumbing ran ?
Like the idea tho ( using the reverse light housing as a filler )
Old 11-21-2020, 10:22 AM   #7
1966c10shrtbd
Used the side fill. Had to run rubber vent tubing up & over the wheel well on both sides to be able to vent when filling at the gas station.
Old 11-25-2020, 07:23 PM   #8
PGSigns
PGSigns's Avatar
Boyd Welding is what I used. Unless you on your knees you dont see it. I also got it black powder coated.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-25-2020, 07:42 PM   #9
bigmoe
bigmoe's Avatar
Tanks Inc universal tank. Doesn't show below bumper. Two optional fill locations.
https://www.tanksinc.com/index.cfm/p...rod/prd121.htm
bigmoe is offline   Reply With Quote
Old 11-26-2020, 04:42 PM   #10
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Here's mine for Fuel Injection Engine.. It's a 1995 Roadmaster Tank, Hanger and Hardware.. 22 Gallons and Plastic will out last the truck.lol.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 11-26-2020, 05:40 PM   #11
Vortech
Vortech's Avatar
Bigmoe, 66shortbed, can you show how you plumbed your gas tank. Assume they are both side fill tanks?
Vortech is offline   Reply With Quote
Old 12-01-2020, 11:15 AM   #12
raic65
raic65's Avatar
Using a Rick's VaporWorx tank on my 66 fleetside. I did a bed fill for my swap.
raic65 is offline   Reply With Quote
Old 12-01-2020, 11:36 AM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
Do you have to modify the frame for the side fill on that tank?
Old 12-01-2020, 11:49 AM   #14
bigmoe
bigmoe's Avatar
The Tanks Inc. tank I referenced has two optional fill locations, one on top and one on the upper side. My truck is away in storage for the winter so I can't get pics but I have a picture I save of the guy who I copied with the exception that I used a metal elbow where it goes up through the floor. I had to make a hole in the frame to route the hose.
Old 12-02-2020, 12:12 PM   #15
bigmoe
bigmoe's Avatar
Found a picture of my tank installed. Tanks Inc. USPT-GH. (the vent was moved higher within the fender once the box was installed.)
Old 12-02-2020, 01:41 PM   #16
The Rocknrod
Moderator
You ran the fill tube thru the frame?
Old 12-02-2020, 03:36 PM   #17
bigmoe
bigmoe's Avatar
Yup.
