07-23-2019, 03:53 PM | #1 |
Limited Slip posi swap
I pulled the diff out of a 94 caprice cop car with the limited slip. What all do I need to do to swap it into my 94 C1500? I am not changing the gear ratio.
Swap ring gears obviously and replace the bearings. Can i just put the posi in place of the old carrier using the same shims? Do I need to do something more complicated? |
07-23-2019, 05:00 PM | #2 |
Re: Limited Slip posi swap
so, i am inquiring about this swap...are the shafts the same splice ?
what year did you grab the carrier from ? you need to install and measure backlash...moving and shimming accordingly to achieve the .006"-.008" play. lets us know how this pans out. |
07-24-2019, 06:16 AM | #3 |
They are the same 30 spline so no reason shouldnt work. But they aren’t rebuildable from what I’m told. But gotta be better than the grenade lock.....
07-25-2019, 01:05 PM | #4 |
Does anybody have any direct experience doing this?
