08-08-2019, 10:41 AM | #1 |
Led dash lights
I need help. Can you put led 194 lights in the dashboard to replace the 0ld 194 bulbs?
08-09-2019, 10:09 AM | #2 |
Re: Led dash lights
yes. I bought some of ebay and mine are even dimmable.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
08-09-2019, 10:10 AM | #3 |
Re: Led dash lights
Yes you can. But the old wire rheostat dimmer in the light switch won't work any more as they won't draw enough current. Some versions are also polarity sensitive. They will light inserted one way and be dark if inserted the other way.
I purchased some from superbright LEDs: https://www.superbrightleds.com/ that didn't care about polarity. They also come in colors if you want to experiment with different back light colors. |
08-09-2019, 05:15 PM | #4 |
Re: Led dash lights
I replace mine with LEDs and it is much better. I bought dim-able LED lights. If you put them in backwards in the holder they wont work so just flip them around. Easy upgrade
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
08-10-2019, 11:29 AM | #5 |
Re: Led dash lights
Did you replace all the dash lights or just the 4?
I replaced all my dashboard lights and now none of them work. They Are YITA MOTOR 2825 , 158, 192, 168, 194. It doesn't say if they are demmable lights or not. Any suggestions? Really need help. Last edited by Rig7; 08-10-2019 at 11:52 AM. Reason: Added |
08-10-2019, 12:00 PM | #6 |
Re: Led dash lights
08-14-2019, 04:58 PM | #7 |
Re: Led dash lights
It even worked in the socket for the shift indicator fiber optic cable.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
