08-16-2019, 01:38 PM | #1 |
Carpe manana
Seeking fishing advice
I’m trying to get back into fishing after a hiatus of many decades and plan to try my luck in the local (tannin-rich, tea colored) rivers for small mouth bass and maybe some pan fish in local lakes. I have a 6.5’ fast action rod, a Daiwa-made Scheels spinning reel outfitted with 10 lb braided line, and a small selection of poppers and rubber worm mimics that affix to hooks (weighted and non-weighted).
Should I use a monofilament leader on the braided line and a swivel for my lures/hooks, tie a swivel to the braided line to attach lures etc, or skip a swivel altogether and tie directly to the braided line?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-16-2019, 03:07 PM | #2 |
Post Whore
Re: Seeking fishing advice
Any reason why you need braided line?...all we use is mono in 6-8lb test for smallies...4lb for pans...no swivels
08-16-2019, 05:31 PM | #3 |
Carpe manana
Not really - sales guy said it couldn't hurt and doesn't have memory.
08-16-2019, 11:18 PM | #4 |
blood type; Retumbo
I would hang out at a local bait shop and ask the guys there
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
08-16-2019, 11:42 PM | #5 |
Probably no "right" way. With a spinning reel I've always used 4, 6 or 8# mono with a swivel/snap. I've always used a mono leader with braided line on a casting reel, unless you are after a big one such as a musky. Then it's a casting rod, 20# braided line and a wire/cable leader. The idea of the mono leader is so the fish won't see the line.
08-17-2019, 08:49 AM | #6 | |
I'm also a member at crappie.com. Check out the forum there and you might get some helpful information. I'm mostly on the Arkansas section. Good luck.
GoTennTitans 1987 GMC Sierra 1990 GMC Sierra (stolen) 2003 Chevy Silverado |
08-17-2019, 09:47 AM | #7 |
Pete I would definitely use a 8lb fluorocarbon leader attached to your already spooled braided line for the smallmouth. I dont use braided I strictly use a fluoroclear line or mono. The brand I use is P-line. I mostly use 4lb or 8lb for crappie, walleye and white bass. My brother fishes small creeks in Illinois for smallmouth and uses poppers and he says a fake worm with two hooks he gets at walmart. For them bluegill you cant beat worms. My favorite bluegill rig is a slip bobber rig. You can set it to any depth. Get a balsa or plastic slip float that is hollow so you put your line through the top first then tie a hook #4 or #6 gamakatsu or the red eagle claw from walmart. Tie a small rubber band above the float one knot and cut the tag ends to set your depth and small removable split shots one 12-18' above the hook and another 12' above that. The size of the split shot is how you adjust how the float sets so if it sinks use smaller split shots. The fish when they bite dont feel the weight of the balsa float as compared to traditional plastic bobbers. Then all you need is a beer a comfy chair and lots of skeeter repellent.
08-17-2019, 09:50 AM | #8 |
Cane pole / hook / line / worm . The fish don't know what kind of rod and reel you have .
Definition of irony = Buy a $60,000.00 truck to pull a $75,000.00 boat loaded with $5,000.00 of tackle to run 90 miles an hour across the 2 mile long lake to fish 10 feet off the shore ...
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-17-2019, 09:59 AM | #9 | |
08-17-2019, 10:35 AM | #10 | |
08-17-2019, 11:01 AM | #11 |
Now this is fishing , if your going to go big ,GO REAL BIG a set of 7 marine engines a 31 foot center consol and trailer will only set you back about $300,000.00
https://www.seven-marine.com/motors/seven-627sv/
08-17-2019, 01:29 PM | #12 |
Post Whore
Wow..!!...never seen those engines.....
08-17-2019, 04:48 PM | #13 |
Last time I checked they run about $85,000.00 each
08-17-2019, 05:52 PM | #14 |
Keep it simple. Use what you know. What worked ten years ago still works today. Simple swivel and whatever line you like. Don’t take it seriously and you’ll catch more fish than you ever thought. And if not just tell’em they got away.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
08-17-2019, 07:21 PM | #15 |
Post Whore
I guess that's why I never heard of em...haha
08-17-2019, 10:08 PM | #16 |
Carpe manana
Guys thanks for all the suggestions and commentary. Good stuff. I’ve affixed a monofilament leader to the braided line and swivel at the end. I’ll hit the river ASAP with one of the poppers I have and see what happens. Happy to have more input.
