08-17-2010, 11:09 AM | #51 | |
Re: Who's running power windows?
08-18-2010, 11:18 AM | #52 | |
Still plays with trucks
Once I find a decent driver side door to work on I will do a write up on the process and post up some pics.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
09-27-2013, 05:18 AM | #53 |
Location: Northern Ca. at the base of the valley just entering the sierra foothills
Hello and good day.. You had said: [/QUOTE]I have a custom interior so I went with a double switch mounted in the console and used a set of stainless "hot-rod" style wire looms to run the wires out the front of the door into the cab which turned out quite well.[/QUOTE]
Question. How did you decide where to run the wires through the door and the post. Did you drill the hole for the loom in the door and the post with the door closed from the inside of the door? I remember years ago when I ran the speaker cables through the side panel. What a pain.. It appears to me that the loom has to be able to remain completely through the side panel when the door is closed and open.. so that is feeds in and out without hitting the inside of the door panel wall if it was too short? Sure would appreciate a picture if possible, if not I am sure I can visualise what you did if you explain it to me.. It is the one thing that has been stopping me from putting the conversion in for so long.. Can't remember the brand off hand, but 6 years ago it was considered the best on the market, with true delco motors and oem duplicate factory switches.. I have the doors part way apart getting ready to put regulators in and I am thinking, hmmmm,, I have the conversion kit.. should I put it in? I thought it might even be necessary to remove the doors to drill the holes in the post, and possible even the door.. appreciate your time and input.. thank you..
1970 Chevy 4x4 pickup w/72 running gear. 2 1/2" custom spring lift. Brand New 383 stroker-360hp. by Smeding. Edelbrock EFI Fuel Injection. Rostra Cruise Control, 700r4 conversion. ARB Locker/373. Disciple of our Father YHVH and the Lord Jesus Christ. |
09-27-2013, 06:39 AM | #54 |
Its a Truck Thing......
Would love to send pics, but I am in Afghanistan for a few more months. The previous owner drilled holes in down in that area. I would put in power windows every chance I get. I love the mod.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
12-08-2015, 02:13 PM | #55 |
I'm stoked. Thanks everyone!
02-26-2016, 05:02 PM | #56 |
02-26-2016, 05:13 PM | #57 |
subscribed
