Old 07-29-2020, 10:57 PM   #1
Andrij
Andrij's Avatar
Another no start
So I have a 1995 GMC K1500 w/350 tbi
I charge my battery & it reads 12.75V @538 CCA
Motor turns over
I've tried both fuel & starter fluid in the throttle body
So I've assumed electrical. The spark plugs are a year & a half old but look normal on the electrode & still in good shape.
Ive swapped out the Ignition Coil for a new one & acts the same as the already installed Delphi & wires (both 2 years old) & fuel pump too.
Distributor is a year old. & has ran well since I installed it.
Now Im not ruling out bad parts, I went through a hell of 3 distributors all of which were brand new. I drive 100mi twice a month, & the truck sits the rest of the time. But I would like to hear your thoughts & advise.
I don't have a second person so I haven't found a way see if there is spark.
& Thank You very much.
Andrij is offline   Reply With Quote
Old 07-30-2020, 10:37 AM   #2
Kudzupatch
Kudzupatch's Avatar
Re: Another no start
If nothing happens with starting fluid it is safe to assume you have no spark.
I would be betting on the ignition module inside the distributor. I have enough issues I keep a spare in the glove box.Of course it could be cap, rotor etc. but I would still bet on the module being bad.
If you have a tachometer and it doesn't move that that is good indication the module in bad.
Kudzupatch is offline   Reply With Quote
Old 07-30-2020, 11:41 AM   #3
on seems like spark. I have had a wire break on the distributor that connects near the centershaft. I did not catch it till the 3rd time pulling the distributor trying all sorts on things on my old one.
Only other thing I can think of is their is a second oil pressure sensor/switch on some models that if truck has low oil pressure (it was next to oil filter underneath truck), it doesn't let it start. My 96 had a sensor that was failing that drove me nuts. Not sure if your year would have one or not.
Old 07-30-2020, 11:01 PM   #4
Andrij
Andrij's Avatar
Thank you
I do appreciate your input & will take apart the distributor next time Im home & look at the wires.
After 3 Distributors I thought I finally had a good one.
I was thinking last night coolant senor too, When they go out -200 something degrees & the truck doesn't start. Ha! Since mine's 2 years old & stuff don't lastno more.
Going backover the road & won't be back for a month. Will update then & I appreciate y'alls taking a moment out to advise me.
Old 07-31-2020, 08:10 AM   #5
Kudzupatch
Kudzupatch's Avatar
Just to be clear here, if a module goes bad you will not see bad wires or any other indication of it being bad. Some auto parts can test it or you can swap it out.
Old 11-06-2020, 05:31 PM   #6
Andrij
Andrij's Avatar
It was the distributor! Thanks y'alls!!!!!
Be nice if they could make a good distributor that works or lasts... just saying.
Old 11-06-2020, 08:16 PM   #7
Good to hear you got it ironed out. It is frustrating when new parts are bad.
Old 11-09-2020, 07:48 AM   #8
sntrym95
sntrym95's Avatar
This one has worked really well for me. It's not cheap like the others, and it's made of quality parts.
https://www.summitracing.com/oh/part...50200/overview
Mike
sntrym95 is offline   Reply With Quote
Old 11-09-2020, 07:18 PM   #9
speedygonzales
speedygonzales's Avatar
Better late than never
I'm betting you were getting these at cheap auto parts stores and not good brand name parts.
This should be a lesson to not get difficult electrical parts from the local auto parts store unless they are well known brand name parts.
Trust me I worked at O'Reilly's for nearly 2 years and I know crappy parts when I see them.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
