Old 10-13-2013, 02:46 PM   #26
leddzepp
Moderator
leddzepp's Avatar
Re: rear mounted Fuel tank?
Using a Camaro tank allows you to put the filler behind the license plate. If I ever did this mod again, this is the route Id go. The side marker and taillight ideas are great, but a lot of work and if you live in a state where they have giant rubber boots on the filler nozzles, it's about impossible to fill your tank without making a huge mess
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 10-14-2013, 10:23 PM   #27
70blackfish
I have seen a guy used a ford falcon fuel tank...fit was really well but not sure what he used for a sending unit...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 05-07-2016, 09:08 PM   #28
infinite-foamies
I am using two stock Sub tanks. One in OEM location and one behind that cross member, with a trailer hitch, and the trailer connector/winch connectors are going behind the license plate. Yes it is tight but it should work.
I am using the OEM(71') Filler neck on the front tank, got a factory cut out filler neck 1/4 panel mount from Vintagechevytrucks and what I presumed is a 67' Filler neck as the cap from my 71' did not fit. Just got a 67' Cap from my FLAPS and it fits but does not turn... Does anyone know what changed between the caps/filler necks over the years?
infinite-foamies is offline   Reply With Quote
Old 05-07-2016, 10:04 PM   #29
n2classics
http://67-72chevytrucks.com/vboard/a...1&d=1462672888
I put a hagan pop up door in my left rear inner fender. This picture does not show the door installed, but you can get an ideal.
John
n2classics is offline   Reply With Quote
