Old 09-17-2013, 11:59 AM   #1
peglegs
peglegs's Avatar
New S-10 frame/engine id
hey all,
i recently aquired a lost interest project 1940 I H truck with a complete brand new s-10 4x4 rolling frame, V6 engine, 5sp.trans etc.im having difficulty searching for my numbers to identify what year it is so far i believe it is a 92 here are my numbers
fr. rt. pad = T0246UTC
block casting rt. rr.= 10105867
head casting =14094768
dr. side pad stamping/rt rr. top frame rail (same #'s) =CLZ233333
if im correct on the year what do i need or how does the transfer case shifft when its a stand alone, non computer regulated ? changing the tbi to a carburated manifold & the dist problem eliminates that ill need the hyd clutch slave & booster
can u please help or direct me to the site to decifer the frame & engine #'s thanks a bunch
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 09-18-2013, 07:32 AM   #2
andrewmp6
Re: New S-10 frame/engine id
I'm guessing before 94 like 1990ish.
andrewmp6 is offline   Reply With Quote
Old 09-19-2013, 12:18 AM   #3
peglegs
peglegs's Avatar
ty Andrew
Old 09-20-2013, 02:45 AM   #4
andrewmp6
On the t case you might have better luck on http://www.s10extremist.org/forums/ they are more of a off road s10 forum where the rest i have been on are more 2wd slammed type.
Old 09-27-2013, 11:25 PM   #5
peglegs
peglegs's Avatar
my local chevy dealership tells me the only numbers that can identify my chevy is the actual VIN ??????? engine, frame etc cannot. also I have 6 lug wheels & from 87 - 02 that he checked s-10 has 5 lug any help greatly appreciated im beginning to think its not an s 10
Old 09-29-2013, 08:34 PM   #6
esbstuff
pic of the from frame horns would help...
esbstuff is offline   Reply With Quote
Old 09-29-2013, 08:40 PM   #7
esbstuff
5 lug S-Series, 6 lug 1500.
My guess would be 88-98. Since it appears tbi, 88-95...
I would think that this number : "dr. side pad stamping/rt rr. top frame rail (same #'s) =CLZ233333" is the last of the vin...
Old 09-29-2013, 10:42 PM   #8
peglegs
peglegs's Avatar
esbstuff ty for responding after I determine what truck this is my next question is can I make the 4x4 work with switches???
Old 10-06-2013, 06:32 AM   #9
andrewmp6
Yeah 6 lug means full size truck see how long the wheel base is on it.On the t case see if you can find any markings to a model number on it.If its a push button 4x4 case you could rig it up to work like that.
Old 10-06-2013, 02:53 PM   #10
peglegs
peglegs's Avatar
Andrew the wheelbase is 118" heres a pic of the t case tag tyvm for your help
this is a quote from another thread
"While the S10 units are internally the same, they have their shifter tower sitting right at the end of the tail shaft, and they have only 5 bolts for the transfercase instead of 6."
in the last pic are these the 5 bolts in question?
another quote
"You can also bolt in a 96 - 06 5 speed into your truck if you are willing to switch over to the internal clutch slave / throwout bearing combo."
I have a slave cylinder on the bell housing
Old 10-07-2013, 01:50 AM   #11
andrewmp6
I think its a 88-98 gm truck short bed reg cab is 117.5 inch wheel base,Its a 6 lug the t case is a np241 which was only in a full size truck.The bad news the np241 was a shifter in the floor type but i think you could swap to a push button t case if you want.The np243 had 4 high 4 low 2 high the np246 had 4 low 4 high 2 high and 4 wheel auto.
Old 10-07-2013, 02:00 AM   #12
peglegs
peglegs's Avatar
would i have a functional 4x4 with a floor shifter? jegs or summit have a shifter or do I find a 88-95 p/u
im at the point where my project is at a stall im thinking that getting the 4x4 functional worked out is the key you guys think im on the right track? thanks again
Old 10-07-2013, 02:15 AM   #13
andrewmp6
As it is now i think you just need a the floor shifter and linkage for it.
