Old 09-30-2013, 08:16 AM   #1
Dale99
np205 to 4l60e odd year
I am picking up a 1995 tahoe to take the engine/trans and put in my 72 jimmy. Ive done some searching on here and noticed that advanced adapters makes the kit to mate up my np205 to a 4l60. But noticed it leaves out years 93-95. I did an online search and noticed 95 is an only year transmission.
Can anyone tell me whats different about the 93-95's. Or will a 96 kit work? Or when doing this swap do I need to "dumb it down" to a 92 year pcm and transmission?
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 09-30-2013, 08:45 AM   #2
Bigdav160
Bigdav160's Avatar
Re: np205 to 4l60e odd year
A 4L60 is a mechanically shifted transmission.
In 1993, pickups became electrically shifted (4L60e). In 1995 the torque converter clutch became computer pulse width modulated.
I believe in 1996, the case changed to a bolt-on bell housing and 6 bolt extension housing.
AA leaves out the 93-95 because that adapter has no provisions for the VSS sensor to shift the transmission.
edit: you might be able to use adapter 50-8505 and adapt a VSS to it. This might require the engine to be moved forward and the transfer case moved back to accomodate the extra length.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-30-2013, 09:36 AM   #3
Dale99
If its just the vss, I could install one of the inline cable to electric pulse vss gadgets. I thought I would have to do that anyway.
Old 09-30-2013, 08:04 PM   #4
Dale99
I'm starting to think the little gas I could save having over drive.... I could buy A LOT of gas for the 1000bux it would cost to get this trans in there. Then if I do electronic, id really really like to do the 4l80e. I think I may wait and do this later. I just need this thing back to moving on its own power.
Old 09-30-2013, 10:13 PM   #5
Bigdav160
Bigdav160's Avatar
If you already have the motor and transmission I don't think it would cost $1000 to transplant it into your Jimmy.
But it depends on your skill level.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 10-01-2013, 03:41 AM   #6
andrewmp6
What trans did you have the np205 on before?
andrewmp6 is offline   Reply With Quote
Old 10-01-2013, 06:43 AM   #7
Dale99
The kit is 700'ish dollars, plus taking the trans to a shop to have them install the main shaft.
I currently have a th350
Old 10-01-2013, 07:01 AM   #8
andrewmp6
I found something http://67-72chevytrucks.com/vboard/s....php?p=3697343
Old 10-01-2013, 08:09 AM   #9
Dale99
correct, I have looked at that several times. That kit is around 700bux. It is also not listed specifically for a 95 model. They show nothing for 95, so it makes me wonder what all I would have to do.
http://www.advanceadapters.com/categ.../0/0/7/0/24/0/
#50-5310
Old 10-01-2013, 08:27 AM   #10
Bigdav160
Bigdav160's Avatar
That kit is meant for a 6 bolt extension housing case ('96 and up)
Your's has four like a 700R4/4L60
You want a 50-6900. Then a means to add a VSS. Perhaps something like this pulse generator can be adapted to the NP205
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 10-01-2013, 12:30 PM   #11
Dale99
So I dont need an adapter? Just a different input shaft? That I can afford, lol.
Old 10-02-2013, 01:41 AM   #12
andrewmp6
Its a out put shaft that goes in the trans,Basicly you have to almost rebuild the trans to put it in tho.
Old 10-02-2013, 08:04 AM   #13
Dale99
I figured that.
Old 10-03-2013, 03:24 AM   #14
andrewmp6
What about like running a np241 temp tell you save up to run the 4l80e np205 like you want in the end.
Old 10-03-2013, 06:36 AM   #15
Dale99
I still have the cost of buying that tc. Then likely having driveshafts made, plus figuring out how to shift it(isn't that an electric one?).
Old 10-03-2013, 07:13 AM   #16
andrewmp6
I think its a floor shifter i know it was used in the later k5 blazers 88-91,And i think it was carried over in the 88-98 body style trucks as well.
Old 10-03-2013, 08:13 AM   #17
Dale99
You got me to go pull up a picture. If this is correct, looks like the front driveshaft is on the drivers side, not passenger.
1994 s10 blazer 4x4
Old 10-04-2013, 03:22 AM   #18
andrewmp6
What about a np208 it was used 81-87 and even came factory on a 700r4 so the swap might be bolt on for you.Its not a bad t case if you don't run anything over 37s or hardcore off road.
Old 10-04-2013, 07:17 AM   #19
Bigdav160
Bigdav160's Avatar
This looks like an easy enough modification VSS in a NP205. That is, if you know someone with machine tools.
You'd lose your cable driven speedo though.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 10-04-2013, 09:05 AM   #20
Dale99
Andrew, I dont mind switching cases. But again, any other case I put in this requires me buying the case, and whatever for driveshafts. Potentially costing as much or more.
Bigdav, I did come across that google searching. I like it. But I actually need digital and cable driven. So I think the jegsthatrun vss device is going to be my best bet. I just need to find out if the ecm needs the 8000ppm or less.
Old 10-04-2013, 01:45 PM   #21
Bigdav160
Bigdav160's Avatar
Don't take it to the bank but I think GM PCM's need 4000 ppm.
The output shaft isn't that hard to install with a little coaching. If the trans is on a bench I can have it out and in within 30 minutes.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 10-04-2013, 03:42 PM   #22
Dale99
I was thinking it was either 2000 or 4000.
Wish you lived closer, you'd have a few extra bills in your pocket.
