Old 03-17-2017, 08:03 AM   #126
del4fun
del4fun's Avatar
Re: If you had the money what would you do to your truck?
Now what would do?
US ARMY RET, SUPPORT THE TROOPS
1972 Custom/10 Short Fleet 4.5/ 5 Drop
Dogg Pound Customs
del4fun is offline   Reply With Quote
Old 01-21-2018, 11:26 PM   #127
del4fun
del4fun's Avatar
What would you do, with that money?
Dogg Pound Customs
Old 01-22-2018, 12:01 AM   #128
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'd buy a new truck and pitch the camper shell off the current truck and use it for a real truck. I'd have the new truck with all the new sh...tuff which would be good for mileage even when towing. Hey, who am I kidding! I'd be floating in money. What would I care about mileage?
~Steven
Simi Valley, CA
Old 01-22-2018, 12:27 AM   #129
basketcase
basketcase's Avatar
Gear Vendors overdrive for my Turbo 400.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 01-22-2018, 03:20 AM   #130
In The Ten Ring
If I had the money, I'd buy or build a proper garage, outfit it for vehicle restoration----all the tools, paint booth, etc. and I'd hire a real pro, someone with a good personality that I could work with. This guy would show me how to properly do a frame-off restoration on my truck, with welding repairs, etc. I'd pay him to come every day and we'd work on this till done.
In The Ten Ring is offline   Reply With Quote
Old 01-22-2018, 03:37 AM   #131
PaulJWood
Install headlights, big type
Upgrade the tire
Build a big garage
PaulJWood is offline   Reply With Quote
Old 01-23-2018, 11:17 PM   #132
mike16
I'd buy a pair of those POS cast iron tow hooks
mike16 is offline   Reply With Quote
Old 01-24-2018, 08:15 AM   #133
Barnfind46
Barnfind46's Avatar
Hey Mike! You have the money! why not get two!
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 01-24-2018, 04:26 PM   #134
Colt_1911
Colt_1911's Avatar
I would just buy this one
Colt_1911 is offline   Reply With Quote
Old 01-24-2018, 04:48 PM   #135
palallin
I would return it to pure, bone, NOS stock, as brand new as it could be made with NOS GM parts. What would not be NOS would be original but lovingly restored to as near factory condition as humanly possible. it was a perfect truck for me brand new, and I know of no way to improve upon it.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 01-24-2018, 09:15 PM   #136
pryorstemmed
4wd Enthusiast
pryorstemmed's Avatar
^ same for me!
*1972 Cheyenne Super SWB K10 Original Paint 350/350 AC (Added) Tach/Tilt
*1972 Cheyenne Super SWB K10-Buckets/Tach/Tilt/Wood Bed/Manual Throttle/Marker Lamps
*1972 Cheyenne Super Custom Camper K20 AC/Tilt/Aux Tank/Aux Battery/Wood Bed
*1970 Olds 442 W-30 M-21 4-speed
*1978 Ford F250 4x4 Ranger-Explorer-Camper Special Marti Report: 1 of 1
*1986 K30 Silverado Crew Cab 502/TH400
*2002 Silverado LT 2500 Duramax Long bed Crew Cab 4x4 107K original miles
*2022 RAM Bighorn 1500 Waldoch edition ...Daily Driver
pryorstemmed is offline   Reply With Quote
Old 01-25-2018, 03:01 AM   #137
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I can safely say I'm deep into mine. That or it's deep in me.....keep it clean. What was originally a ("will only cost me 18K") will be more like 36K.
That's with me doing most of the work less body/paint/powder coat. And the truck is in great shape to begin with. Everything will be new or refreshed down to 99.9% of the original hardware. Only shortcut is I won't rebuild the engine. 40K on the rebuild, runs like a top and the oil always crystal clear. Same with the antifreeze.
Like the guys above me, factory is the goal. There's some limitations for sure. Good luck finding NOS brakes, exhaust, shocks etc., pretty much most of the under-carriage. Putting a 2.5/4 drop on it too, so different leaf springs and spindles.
Basically:
  • Factory interior. The vinyl is in excellent shape, less the seat. I'm iffy on an original look bench cover versus something with a different touch. I may carpet the floor. It had a rubber mat.
  • Factory engine compartment. Exceptions being R34 A/C, GM HEI distributor, OER radiator. I'll lose the voltage regulator and TCS business. I'm leaning toward an electric choke kit on the Rochester, so the stove pipe will be for "pretty". I MAY pull the battery box off my other truck, or just use the replacement I picked up from Manes. I'm reinstalling the EEC vapor canister system.
  • Factory exterior. NOS and not exactly cheap. Only thing I'm changing is the antenna. High crown and fat ball fixed mast. Basically a mix of original truck parts less the fat ball. The set-up was factory on a 67-68 Corvette, and may pull-off nicely with the deluxe paint scheme.......................73 truck rallys, with an option for the stainless version cap on the original wheels. Nice to have choices.
  • Under carriage will be original-esque.
Money pit. More time than money first time out. will control your life..........
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-25-2018, 11:48 AM   #138
1SG.Rob
1SG.Rob's Avatar
Get all the rust removed and have a high quality repaint job to match the SPID.
1SG.Rob is offline   Reply With Quote
Old 01-25-2018, 12:28 PM   #139
bmfm64
bmfm64's Avatar
I told my wife I figured I could build mine exactly the way I wanted it for 30k. I was wrong... I'm pushing 100k
bmfm64 is offline   Reply With Quote
Old 01-25-2018, 01:58 PM   #140
71CHEVYSHORTBED402
Better than alcohol, drug abuse or gambling
Tony
Old 01-25-2018, 11:17 PM   #141
el_fantasma
el_fantasma's Avatar
Build a four vehicle garage and invite Chris 63GENIII and Eric chevyland to hang out with me.
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
Old 01-26-2018, 09:02 PM   #142
elkniks
elkniks's Avatar
A pair or Warp 9 or 11 electric motors, a whole lot of batteries, and some wicked controllers. If some one wants to donate parts, I'm totally in. Instant crazy power!
elkniks is offline   Reply With Quote
Old 10-28-2018, 09:23 AM   #143
del4fun
del4fun's Avatar
That is really the best thing you could do . We all need more room!
Dogg Pound Customs
Old 10-28-2018, 11:33 AM   #144
67swb72klb
67swb72klb's Avatar
I don't want to type that much...
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 10-28-2018, 06:21 PM   #145
In The Ten Ring
I probably typed what'd I'd do to my truck on here already but the "new garage" idea is a good one!
I'd build a new garage too but I'd have to move first (fine with me). Garage would be a ferro-concrete job (dome shaped) and part of my new dome-house mansion. I want at least 3 bays but large enough to house a lift and deep enough to handle car storage and that for around 10 cars/trucks.
Old 10-28-2018, 06:28 PM   #146
68bowtie
68bowtie's Avatar
I would have a very reputable shop restore my 68 to 100% factory original. Maybe someday like 30 years from now when I retire (assuming we are still allowed to drive vehicles that burn fossil fuels).
Photoshop rendering...
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 10-28-2018, 06:31 PM   #147
Operatorfailure
I already sold my truck, but I would buy a 69 to 72 Blazer, swap a 68 front clip on it, slam it with a turbo LS and a T56. All the Creature Comforts, AC, he, heated and cooled seats.
My 68 Stepper build
Operatorfailure is offline   Reply With Quote
Old 10-28-2018, 07:36 PM   #148
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
“If I had money, I’d tell you what I’d do. I’d go downtown and buy a.....”
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 10-28-2018, 11:47 PM   #149
68bowtie
68bowtie's Avatar
Never owned a mercury. Don't think I ever will.
Old 10-29-2018, 12:24 AM   #150
bbrriiaann1973
I already did!
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
