Old 05-24-2020, 10:43 PM   #101
ManNamedJed
Re: 1971 4x4 Suburban Project - the 'Family Adventure Wagon'
Mounted up new balancer and timing tab.
ManNamedJed is offline   Reply With Quote
Old 05-24-2020, 10:44 PM   #102
ManNamedJed
Fuel line is in the way, so that will have to get relocated.
FYI - if anyone else does this, the instructions say to mount the water pump first, but it would go a lot easier if you did it after mounting the AC brackets
Another issue, the new bracketry is for a R4 type compressor and I have a Sanden 508. There are some adapter kits out there, so I gave that a try. Here is initial mock up.
Old 05-24-2020, 10:46 PM   #103
ManNamedJed
New alternator on. It moves the alternator up and in, so I had to make a new charging wire, and add the CS-SI adapter pigtail.
PS pump also moves up and in, so lines will need some tweaking. Fun stuff!
Old 05-24-2020, 10:48 PM   #104
ManNamedJed
Was making good progress and decided to tighten down the AC Compressor. I think the adapter was based on different bracketry, because some things weren't lining up great. I thought I had it good, and was tightening the last bolt and 'POP!'.
So yeah, this happened.
Old 05-24-2020, 10:52 PM   #105
ManNamedJed
Also realized my water pump is now reverse flow, so I had to go get a new reverse flow fan and fan clutch - to replace the ones I added just last year. Also had to go to several places to find the odd ball fan clutch bolts, which were different than the oddball fan clutch bolts I had to track down last time.
Ended up getting a new fuel pump that points the in/out in a better direction. I probably could have made the old one work, but I didn't know how old it was and I figured, while I'm at it.....
I think the AC would be okay with the broken ear. It is firmly attached at three other points. I could also clock up up to the next set of tabs too, so its not the end of the world, just made for a frustrating day.
And I think my helper would rather be working on plumbing projects.
Old 05-25-2020, 09:10 PM   #106
LockDoc
The Older Generation
LockDoc's Avatar
Seems like the bad luck never ends....
Yup, your helper looks like he is ready to go use the plumbing....
Where did you get the serp pulley for the Sanden 508? I need one of those too. Have a part number by chance?
Thanks,
LockDoc
Leon
Old 05-25-2020, 09:33 PM   #107
HO455
HO455's Avatar
Thumbs up Re: 1971 4x4 Suburban Project - the 'Family Adventure Wagon'
As is my usual I scrolled down looked at the picture before reading and went oohhhh d0mm!!!
I know your pain brother.
Look's like your doing well otherwise!
Keep up the good work.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 05-26-2020, 11:07 AM   #108
ManNamedJed
Thanks,
LockDoc
PN MCH-P475 at Summit. Its $135. You can find them for around $100 on amazon and ebay, but since summit is local and is easy to do returns, I don't mind paying more there. I was actually there three times times weekend and will be back today.
Old 05-26-2020, 05:20 PM   #109
LockDoc
LockDoc's Avatar
Thanks for that. I will get one ordered. I wish I had one close to me.
LockDoc
Leon
Old 02-25-2021, 05:15 PM   #110
ManNamedJed
Not many updates lately. Got frustrated and didn't touch it for 6+ months.
Took a course on Manual Transmissions, Axles and Transfer Cases at the local community college. Was a cool experience. Got to put the suburban on a rack and run it safely to look for issues. Instructor agreed the issue seems to be in the transmission or transfer case.
Sooo....
I ordered up a NV4500 and 241 transfer case today. $$$$$! However I'm at the point where I just want to throw money at it to get it to a point that its driveable. Hopefully that will give me smooth shifting, overdrive, and cure my vibration issues.
Its going to be a PITA project. Shifter will be in a different location. Will require a different transfer case shifter. Going to convert to hydraulic clutch at the same time. Will require new driveshafts (again). My new exhaust will likely need modified. The trans/case should arrive in 2-3 weeks, so expect more updates then.
Old 02-25-2021, 10:26 PM   #111
LockDoc
LockDoc's Avatar
Good to see you working on it again. I don't know what year NV4500 you are getting or what your current transmission is for sure, but here is a thread where I installed an NV4500 in my '72 C30 using the stock SM465 bell housing, clutch setup, and clutch linkage.
http://67-72chevytrucks.com/vboard/s...d.php?t=673588
LockDoc
Leon
Old 02-26-2021, 11:28 AM   #112
ManNamedJed
Thanks, I've read every NV4500 thread on this board, and yours several times, so I'll certainly be reviewing it. I am still debating whether to go with the stock clutch linkage or convert to hydraulic.
I was also looking at maybe scooting the engine forward a few inches to compensate for the different shifter location.
Midwest Transmission is actually building me a NV4500 with a dodge output shaft to mate with a Dodge 241 as the Chevy pass drop 241s are pretty rare. I requested the taller gearset as I have 4.10s already, and the 241 has a lower low range.
Old 02-26-2021, 12:24 PM   #113
LockDoc
LockDoc's Avatar
Sounds good. Keep us posted on your progress.
LockDoc
Leon
Old 02-28-2021, 10:19 AM   #114
BigBird05
Please fabricate a metal fuel line and don't use the one in the picture.
BigBird05 is offline   Reply With Quote
Old 03-15-2021, 02:46 PM   #115
ManNamedJed
Got some expensive new parts in. Now to get them installed.
Looking at the shifter locations, I think I'm going to try to keep this simple and stick with stock engine location, and use the manual clutch for now. Still need to source a trans mount, and will have to figure out the crossmember mounting.
Old 03-16-2021, 09:26 AM   #116
HO455
HO455's Avatar
Looks like a great addition. Here is some information on how to update the factory clutch linkages so they hold their own compared to a hydraulic clutch.
http://www.superchevy.com/how-to/498...linkage-build/
And a link to the Speedway motors clutch fork which was not mentioned in the article. Using a heim joint on the clutch fork removes some more friction from the linkage making the pedal feel even better.
https://www.speedwaymotors.com/Speed...ork,37080.html
Old 03-16-2021, 08:49 PM   #117
layinrocker65
layinrocker65's Avatar
This is a great build.
53 GMC COE all stock
53 Chevy 3100 Pro Touringish LSA/TR6060
http://67-72chevytrucks.com/vboard/s....php?t=805949
70 Chevy C10 LWB 350/sm465
74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
91 GMC Syclone 370/4L80e PT88 AWD
92 GMC Typhoon 6.0/4L80e twin 65s AWD
20 GMC Sierra 1500 3.0l duramax
layinrocker65 is offline   Reply With Quote
Old 03-17-2021, 10:42 AM   #118
ManNamedJed
Looks like a great addition. Here is some information on how to update the factory clutch linkages so they hold there own compared to a hydraulic clutch.
Thank you! I really appreciate it!
Old 03-17-2021, 09:31 PM   #119
best view
Yep my plumber wears the same shorts wondering what the cost is for them
best view is offline   Reply With Quote
Old 04-09-2021, 09:45 PM   #120
LT7A
I think it's very cool that you're building an adventure rig for your family. Priceless time with your boys working on the truck. Literally, even if you get nothing done. I'll bet there are many who would give anything they have now to go back and have that time again. In fact, my dad has told me that exact thing. Since your boys are working on it with you, the adventure of the adventure rig has already begun. Thanks for telling us about it. PS, I like the truck too.
Old 04-12-2021, 03:48 PM   #121
ManNamedJed
Thanks for the comments. Unfortunately other things have come up and haven't started the trans swap yet. I think I may have to take a few days off work to dive into it.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
