01-28-2021, 09:09 PM | #201 |
Re: Orson the 49 GMC ~ Chris C.
today we repositioned the engine, I think I'm happy with it. tomorrow we'll make it permanent! I think I've been screwed on the intake! I sent him $400, he hasn't answered my email in 5 days. going to contact paypal tomorrow!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 01-29-2021 at 11:45 AM. Reason: flipped photos |
02-02-2021, 08:57 PM | #202 |
Remade the transmission crossmember today, now the driveline is in the right position!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
02-11-2021, 11:16 PM | #203 |
I finally sourced an LS1 intake (minus injectors and rails). Gonna require some creativity With belt routing, the idler pulley interferes With the throttle body.
This is the belt routing we need
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 02-12-2021 at 11:13 AM. Reason: flipped pics |
02-12-2021, 10:57 PM | #204 |
This is the belt routing we need IOT use the car intake! And we finished painting the intake today.
02-13-2021, 08:01 PM | #205 |
theres not alot of belt contact on the crank pulley. Usually at 2/3rds of the pulley is in contact with the belt. So under high load from either the ac or alternator could cause belt slippage. Also which direction does the water pump normally turn on the LS? Ive never looked into one, so re-routing the belt might alter the direction of the pumps rotation.
02-13-2021, 10:29 PM | #206 | |
02-19-2021, 10:18 AM | #207 |
we kept running into clearance problems, in the end we decided it would be way easier to rework the truck harness
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 02-19-2021 at 11:37 AM. Reason: flipped photos |
02-19-2021, 10:22 AM | #208 |
This bracket allows me to use a GM R4 pancake AC compressor
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 02-19-2021 at 11:38 AM. Reason: flipped photo |
02-19-2021, 10:29 AM | #209 |
Here’s the harness after 2 hours of removing plastic sheathing and tape. The Second pic is the pile of what we removed.
02-19-2021, 10:32 AM | #210 |
Here’s a video of JP reworking the harness https://www.facebook.com/10446154501...63174672146253
02-19-2021, 11:35 PM | #211 |
pic 1. This is the Harness after 5 hours of pulling 8 injector, 2 coil, MAF, IAC, TPS, ALT, and trans circuits. we still have a few left, we’ll do on Monday
pic 2 & 3. This is the new harness before sheathing.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 02-20-2021 at 11:14 AM. Reason: flipped pics |
02-23-2021, 11:52 AM | #212 |
The first couple pics are the firewall starting to get welded up. The next few are of the harness coming together, and the last is the leftovers.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 02-24-2021 at 11:27 AM. Reason: flipped photos |
02-23-2021, 01:36 PM | #213 |
Wow, sure am glad I decided to just get the Terminator X Max kit for my LS. Pretty cables all ready to install. A little worried about some reviews that the wires are too short. We'll see!
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
02-23-2021, 01:54 PM | #214 |
yeah, I bought a harness for this one but it was for a car intake and wouldn’t fit! Wound up modding one anyway
02-24-2021, 12:13 AM | #215 |
1.This is the rat's nest of wires we’re dealing with, it’s ever so much harder explaining what to do than to just do it yourself!
2. Here JP combined 2,4,6,8 injecor power into 1 wire 3. Here we are beginning to pin the red and blue connectors, every wire must be lengthened or shortened. All 160 of them!
02-24-2021, 10:33 AM | #216 |
My hat is off to you, as I have no idea what/how you are doing this.
This is why I like carburetors and distributors, and LS motors (computer controlled) scare me.
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
02-24-2021, 11:26 PM | #217 |
They really aren’t that scary, once you understand the function of each sensor. A Wiring harness conversion is actually way simpler than this. But I absolutely hate having the harness run in the side of the motor and I hate the PCM being under hood!
02-24-2021, 11:29 PM | #218 |
1. Firewall progress
2. What we got done on the harness today 3. What’s left
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 02-25-2021 at 11:12 AM. Reason: flipped pics |
02-25-2021, 08:58 AM | #219 |
1) your nuts and i like it
2) are those the auto solder/seal shrink tube deals? how do you like em vs the old school way? |
02-25-2021, 09:44 AM | #220 |
I love them, I buy them in 100 packs on eBay for like $10. Saves tons of time over solder/heat shrink.
02-25-2021, 02:09 PM | #221 |
Skymangs, you make it sound simple, but all those wires intimidates me so much that I stay away from computer controlled engines.
Well done, and like I said before, I tip my hat to you.
02-25-2021, 09:35 PM | #222 |
1. What we got done today
2. What’s left
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 02-26-2021 at 11:22 AM. Reason: flipped photo |
02-26-2021, 08:39 AM | #223 | |
02-26-2021, 09:54 AM | #224 |
ha, ha! I used to be that way, but I realized that the future of hot rodding was LS Engines. And if you’re not growling you’re dying. So it was critical that I learned it!
02-26-2021, 10:06 AM | #225 | |
i'm actually putting a carb on a 2005 truck 6.0L going into my dad's car this summer. different sound and look from EFI, and retains more of the character of driving the car. |
