Old 02-25-2021, 01:54 PM   #1
rayce88
Best Fuel filter location
Pretty simple question ....67 c10 ... bout to plumb my fuel system .... return style 5.3 ... in tank pump ... tank mounted in rear ... where is the best place for the fuel filter ? .... I was thinking the obvious places like frame rail or the cross bar right behind the rear axle ...
rayce88 is offline   Reply With Quote
Old 02-25-2021, 04:01 PM   #2
bigmoe
bigmoe's Avatar
Re: Best Fuel filter location
I went on the inside of passenger side frame rail just forward of the axle. Really anywhere along the fuel line route that's accessible in the future for filter changes. And maybe away from where road dirt might hit it. In this pic I've got paper towel under it to check for leaks on first power up.
bigmoe is offline   Reply With Quote
Old 02-25-2021, 04:36 PM   #3
rayce88
Thanks bigmoe .... that’s about where I was thinking ... just the other side for me ...
Old 02-25-2021, 07:30 PM   #4
mongocanfly
mongocanfly's Avatar
I was advised to keep it and the inline pump as close to the tank as possible...not sure what difference it would make..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-25-2021, 08:18 PM   #5
ls1nova71
ls1nova71's Avatar
In line pumps need to be as close to the tank as possible because electric fuel pumps don't like to pull fuel, they're designed to push it, but the filter can go anywhere. GM even used to bolt them to the back of the engine in the old 2.5 Iron Duke days.
I have mine mounted on the straight part of the frame directly under the cab, so that the exhaust isn't in the way when you need to change it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-25-2021, 08:54 PM   #6
kipps
I would also suggest avoiding interference with the mufflers. If you have single exhaust, run the fuel line down the opposite side. If you have dual exhaust, position the fuel filters either in front of or behind the mufflers. This is purely for ease of access.
Many of us have cussed out the OEM engineers for the gymnastics they make us go through to service our vehicles. Here's your chance to adequately plan ahead, and avoid those frustrating situations.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 02-25-2021, 11:49 PM   #7
LS short box
As suggested above mine is behind the muffler on the left hand frame rail. I don't care for self taping screws so I use a 1/4" bolt to hold the FPR to the frame rail in case you have to replace it in the future.
Old 02-26-2021, 09:30 AM   #8
A1971Blazer
A1971Blazer's Avatar
I located mine in the frame rail toward the front
Aeromotive with replaceable element..just remove the flexible line and the filter cap to replace the element.
should be easily accessible
it's further from the exhaust pipe than it looks in the picture
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-02-2021, 10:27 AM   #9
racecougar
racecougar's Avatar
I put mine on the driver side frame rail with the alcohol sensor.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
