Old 10-26-2020, 11:30 PM   #1
Todd46
New Crossmember for a 62
Check out this beauty! My new auto trans crossmember for my 62 C10
Courtesy of Capt Fab of course. No way I could pull this off!
No excuse now, time to complete the mock up and get this installed.
Todd46 is offline   Reply With Quote
Old 10-27-2020, 09:56 AM   #2
88Stanger
88Stanger's Avatar
Re: New Crossmember for a 62
Nice work!! CaptainFab is amazing....
88Stanger is offline   Reply With Quote
Old 10-27-2020, 10:00 AM   #3
bhap
bhap's Avatar
What transmission are these designed for? Are they for SWB ? Very interested in knowing details - it looks great!
bhap is offline   Reply With Quote
Old 10-27-2020, 10:27 AM   #4
Rickysnickers
He earned is handle with that one!!!
Old 10-27-2020, 05:46 PM   #5
jchav62
1962 C-10
jchav62's Avatar
That's friggin awesome! C-Fab is the man!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-27-2020, 08:18 PM   #6
slepysal
slepysal's Avatar
Nice !!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-27-2020, 09:01 PM   #7
Todd46
Yes, it's for a SWB C10. I'll be running a TH350, but it will fit the TH400 as well and I think a couple others.
I think this will more than handle anything I can throw at it! Great quality
Old 10-27-2020, 09:03 PM   #8
Todd46
Ya it's a beautiful piece of work!
Old 10-27-2020, 10:20 PM   #9
Captainfab
60-66 Nut
Thanks for all the compliments
Old 11-05-2020, 10:36 AM   #10
GWs62
GWs62's Avatar
Ok, can this be true? A TH350 crossmember for a '62??
Will this still fit with the torsion bars in place? The PO of my '62 did a hokey job with the 350/TH350 install and I need something more reliable.
When was the last time you did something for the first time?
We never really grow up, we only learn how to act in public.
GWs62 is offline   Reply With Quote
Old 11-05-2020, 10:17 PM   #11
Todd46
Absolutely true! I have not installed it yet but I've held it in place and it fits great. I'm hoping to do a mock up this weekend if it doesn't rain.
You won't go wrong with Captain Fab. Never seen a complaint about any of his products.
Old 11-06-2020, 10:57 AM   #12
GWs62
GWs62's Avatar
I totally agree!
I have his power steering bracket as well as his power brake bracket. Perfect fit.
BUT - will this crossmember fit with your torsion bars in place?
Old 11-06-2020, 11:40 AM   #13
SkinnyG
SkinnyG's Avatar
It should - the torsion bars are on the outside of the X, aren't they?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 11-06-2020, 03:20 PM   #14
62 Barnfind
62 Barnfind's Avatar
Nice! CaptianFab do you think it will work for a T5 trans?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 11-06-2020, 10:49 PM   #15
Captainfab
60-66 Nut
It will work with a T5 if the mount is in the same location as the Powerglide and TH350 relative to the back of the engine.
Yes the trans mounts I have made will work with the torsion bars in place. This crossmember is patterned after a factory Powerglide crossmember. The torsion bars are below it. The crossmember Todd46 has is not the first one I have fabricated.
Old 11-07-2020, 09:07 AM   #16
62 Barnfind
Thanks! How much are they?
John Z
62 Barnfind
Old 11-07-2020, 10:04 PM   #17
Todd46
Got it installed today. Fits like a glove. Mounting holes lined up perfect. Had to drill the top hole in my frame but the lower two matched up like OEM.
Here's a couple pics so you can see the relation to the torsion bars. Even painted it up pretty so you can see it!
Sorry they're sideways
Old 11-07-2020, 10:47 PM   #18
Captainfab
60-66 Nut
PM sent.
Old 11-08-2020, 10:12 AM   #19
Rickysnickers
Straightened
Old 11-08-2020, 12:32 PM   #20
Todd46
Cool Re: New Crossmember for a 62
Thanks!
Old 11-08-2020, 07:22 PM   #21
Rickysnickers
You bet
Old 11-10-2020, 10:30 AM   #22
GWs62
GWs62's Avatar
Yes, I believe you are right.
Old 10-12-2021, 12:24 PM   #23
bhap
bhap's Avatar
Hey Captain, a couple of quick questions on this 62 rear crossmember - does this bolt into existing holes in the frame? Can this be installed while leaving the original manual transmission crossmember in place? I'm putting in a Saginaw 3 speed using the original rear bellhousing mount and have seen comments that suggest the Saginaw should be supported in the rear - the transmission has a rear mounting boss. If I install this for the 3 speed, will it be in the right place for an automatic if I go that route down the line? Going into a 62 short bed. Thanks for your help.
Old 10-17-2021, 10:01 PM   #24
Captainfab
60-66 Nut
Yes the trans crossmembers that I am fabricating does bolt into the original factory location using the factory holes, plus one more on each side that needs to be drilled. I patterned them after the OEM auto trans crossmembers. IMO you do not heed an additional crossmember on the rear of a Saginaw 3 speed. GM installed them just hanging off the back of the bellhousing. In fact having too many mounting points can cause binding and breakage. If you really feel you need one, I have one welded up and ready to ship.
