Old 06-02-2020, 11:09 PM   #1
lugnut
lugnut's Avatar
Tailgate handle bolts
Does anyone know what years used Phillips heads vs. bolt heads for the tailgate handle? These are on the inside of the gate. What size are the threads and how long are they?
1967 Chevrolet 1/2 ton 4x4
1972 GMC 1/2 ton 4x4
2005 1500 4x4 Suburban
2004 GMC Envoy 4x4 (wife's)
lugnut is offline   Reply With Quote
Old 06-03-2020, 05:20 PM   #2
tdangle
tdangle's Avatar
Re: Tailgate handle bolts
pop one out and measure it. You may need an impact driver to remove them. I would replace with stainless steel, no rust
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-03-2020, 10:34 PM   #3
bhemingson
He may not actually have one to measure. I'm sure someone here has a helpful answer....
bhemingson is offline   Reply With Quote
Old 06-03-2020, 10:42 PM   #4
lugnut
lugnut's Avatar
The problem is I bought a gate with no hardware so I ordered a new handle, rods and latches but it the kit does not include bolts. The attached photo is just an example I was using to refer to. Sorry for the confusion. Thanks.
Old 06-04-2020, 11:08 AM   #5
tdangle
tdangle's Avatar
I did the same, bought a new tailgate with new hardware and no screws. Had to reuse mine which are rusty. Need to change them out. Later today I'll pull one of mine and let you know.
Terry
Old 06-04-2020, 01:27 PM   #6
sick472
sick472's Avatar
I believe they are 5/16-18 by 1/2" long. Someone double check this for me. If you use stainless steel...use anti-seize. The affordable grades of SS hardware galls easily and could cause your handle mechanism to be rather permanent. I used SS button heads with SS rubber bonded washers...turned out nice.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 06-04-2020, 03:54 PM   #7
GMCPaul
Off the top of my head they are 5/16"-18 X 1" but for length I could be wrong and they may only be 3/4" length instead of 1".
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 06-04-2020, 06:27 PM   #8
tdangle
tdangle's Avatar
Just checked mine, original 5/16 18 thread and the thread length is 3/4". Only unique thing about the screw is it is a fairly large shallow round head called a truss head. (yes I looked it up!)
Terry
Old 06-04-2020, 06:47 PM   #9
lugnut
lugnut's Avatar
Thanks everyone.
Old 06-08-2020, 06:52 PM   #10
lugnut
lugnut's Avatar
Is it just me or are these aftermarket handles cheaply built? I bought one, it came damaged and bent. It was really flimsy where it hinges. Called the company and they sent another one but I'm not even going to take it out of the plastic because I can tell it's as flimsy as the first one. Any suggestions on where to get a good one? I found a really nice OEM gate but someone took the handle and hardware before me.
Old 06-08-2020, 06:58 PM   #11
lugnut
lugnut's Avatar
Old 06-10-2020, 09:33 PM   #12
lugnut
lugnut's Avatar
Alright, what an I doing wrong? I bought a factory gate with no hardware. So I purchased a new handle assembly. It did not fit. When bolted in, the handle hits the gate. Took it apart and it looks bent. Box was beat up, maybe damage from shipping. Called the company and they sent a replacement. I could tell it looked the same but tried it anyway. Same thing. Hits on the handle opening. It will not lift up. An I just dealing with cheap aftermarket parts? Or am I missing something simple? I have no original to go off. It hits where I'm pointing in the pics.
Old 06-10-2020, 09:40 PM   #13
lugnut
lugnut's Avatar
Can't post pics for some reason.
Old 06-10-2020, 09:53 PM   #14
lugnut
lugnut's Avatar
try again.
Old 06-10-2020, 09:55 PM   #15
lugnut
lugnut's Avatar
try again.
one more
Old 06-11-2020, 02:03 AM   #16
GMCPaul
Besides posting here I also just replied to 1 of your emails to the office. We shipped you both tailgate handles and I myself checked that there were no issues with the 2nd handle before sending it. They work correctly in both OEM and reproduction tailgates and the looking at your photo of outside of tailgate shows the tailgate handle opening to be bent in several locations. In regards to flimsy the tailgate reproduction handle is just as heavily made as the original's. The issue is your OEM tailgate is damaged around the handle opening.
Paul Jr @ GMCPauls
Old 06-11-2020, 12:17 PM   #17
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Truss head, interesting. I've been calling them high crown. I second 5/16-18 x 3/4. Stamped E even Same screws are used for in-tire carrier and jack accessories springs.
This thread got me thinking, my handle may be bent, though I don't see it. It's too close the molding when I open it, IMO. The handle on my other sits further back and clears easily, but it's bent for sure. Does anyone have a close-up for a properly positioned handle, and can you describe the clearance when you open it?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-11-2020, 09:11 PM   #18
lugnut
lugnut's Avatar
I should have taken a photo of my friends truck. His is original gate and handle and it clears nicely. If guess about 1/4 inch between top edge of handle and gate. I'm on the hunt for an OEM handle locally.
Old 06-11-2020, 09:49 PM   #19
gmc684x4
I think if you elongated the holes a bit you can lower the handle
To give you the needed gap
Many repop parts need a bit of finish alignment
https://m.youtube.com/watch?v=VeRC7TmolnM
gmc684x4 is offline   Reply With Quote
Old 06-11-2020, 10:02 PM   #20
lugnut
lugnut's Avatar
I thought about that but the holes have a raised edge inside the gate, plus that could result in a loose handle situation down the road if those bolts have any movement in the hole.
Old 01-18-2021, 07:08 PM   #21
lugnut
lugnut's Avatar
Does anyone know if there is a difference in the tailgate latch/handle assembly between a pickup and blazer?
