Old 09-10-2011, 09:10 PM   #51
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Dynatech MuscleMaxx Headers
Originally Posted by BigShoe24 View Post
Any idea of the length of the black line? Thanks
installed now....but I'll try to get you a measurement next time I'm under it.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-20-2011, 10:16 PM   #52
BigShoe24
True Addiction
BigShoe24's Avatar
Thanks man, I would appreciate it...
RCC
BigShoe24 is offline   Reply With Quote
Old 10-06-2011, 05:49 PM   #53
68GMCCustom
from underneath, (sticking a tape up from the bottom) it looks like 18.5" - 19" max.
Kurt -
Old 10-18-2011, 09:50 PM   #54
BigShoe24
True Addiction
BigShoe24's Avatar
Thanks, thats would put me flush with the bottom of my frame rails if measured from the top of the exhaust ports.
Did I read you were interested in selling them?
RCC
Old 10-18-2011, 11:05 PM   #55
68GMCCustom
I will be....when I can afford to buy a set of the DT large tube 67-72 LSx headers (they fit better with my long range plans) I'll be selling these Dynatech's.... unless I buy something else to put them on.
Kurt -
Old 10-19-2011, 01:30 PM   #56
mac72
big shoe, if you have a raised crossmember or [dropmember] they will hang 1.5" below the frame.The only way I can see around that is to open the tunnel up to decrease the angle.My output shaft angle is at 3 deg. down & the trans is pretty tight.The headers are first rate anyhow.
mac72 is offline   Reply With Quote
Old 10-19-2011, 02:53 PM   #57
68GMCCustom
here's how they look on a stock truck w/engine at roughly normal (for an LSx) height.
I plan on a complete coil over IFS at some point...meaning I'll probably need the clearance the DT's provide.
Kurt -
Old 10-20-2011, 09:53 PM   #58
BigShoe24
True Addiction
BigShoe24's Avatar
mac72, thanks for the input, bud.
RCC
Old 10-21-2011, 12:28 PM   #59
mac72
Your welcome,my clips off so if you need any measurements or pics let me know.I was sceptical about purchasing them at first because of ground clearance issues until i found that they are higher up than my pan.Just something to consider
Old 01-14-2012, 09:43 PM   #60
dkauffman05
dkauffman05's Avatar
I can't seem to find the headers 68gmccustom used does anyone know the difference in the 67-69 camaro ones? I really wanted to use these but summit's website says not available.
dkauffman05 is offline   Reply With Quote
Old 01-14-2012, 09:53 PM   #61
BigShoe24
True Addiction
BigShoe24's Avatar
Mac, they are higher than your pan? How tall is you pan?
RCC
Old 01-14-2012, 10:00 PM   #62
dkauffman05
Found the 715-19410 and the 715-29410 both thinking about the first ones due to only having a stock 5.3 and the smaller tubes might give me more room.
Old 01-16-2012, 02:54 PM   #63
mac72
7.5" at it's lowest point.It's 1 of those GM conversion pans
Old 02-04-2012, 11:36 PM   #64
BigShoe24
True Addiction
BigShoe24's Avatar
Ok, so the DT Big Tubes don't fit. Passenger side hits on the firewall bad. I'm placing to links below, could you confirm 68GMC these are what your running?
http://www.summitracing.com/parts/DTC-715-29410/
http://www.dynatechheaders.com/m_camaro_70_81.html
Might have to click on LSX on the second link.
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
RCC
Old 02-05-2012, 01:29 AM   #65
68GMCCustom
those on the Dynatech page look like the ones but it appears they changed the part number as they were 115-909400 (30C) when I bought. Also they're not stepped, just straight 1 7/8" primaries x 3" collectors. The Summit pics show stepped and #5 cylinder passing over behind #7....unlike Dynatech's pic.
Kurt -
Old 02-05-2012, 01:52 AM   #66
66ChevyMax
66ChevyMax's Avatar
I found out you can not go by pics on the web to determine what they are selling you.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 02-05-2012, 02:15 AM   #67
68GMCCustom
very true!
Kurt -
Old 02-07-2012, 10:43 PM   #68
BigShoe24
True Addiction
BigShoe24's Avatar
Anyone want to swap?
RCC
Old 02-07-2012, 10:58 PM   #69
68GMCCustom
can't BigShoe....notice our posts above were changed with some words deleted? I guess maybe so, since now it shows you as Premium. I did that for a few years until I felt the site was large enough to support itself.....now I refuse to.
sorry.
Kurt -
Old 02-08-2012, 02:19 PM   #70
BigShoe24
True Addiction
BigShoe24's Avatar
Kurt,
No worries. I went ahead and ordered a set of the Dynatech's. Hopefully I can sale the DT's and the Dynatech's will fit!
RCC
Old 02-08-2012, 05:40 PM   #71
68GMCCustom
Good luck...I hope they work out for you.
Kurt -
Old 02-08-2012, 06:46 PM   #72
dkauffman05
Ordered mine yesterday coming direct from dynatech
Old 02-08-2012, 11:02 PM   #73
BigShoe24
True Addiction
BigShoe24's Avatar
dkauffman, really? I called and emailed and didn't get a response. I am always dumbfounded why more manufactures don't sale direct. I just hope get what I ordered and they fit!
RCC
Old 02-09-2012, 08:21 PM   #74
dkauffman05
They got here today. I ordered 715-19410 from sumit and they were drop shipped from dynatech in 2 days. Summits website says $55 to ship them and I asked my salesman about that and it was wrong it was only $9.50.
Old 02-12-2012, 12:40 AM   #75
BigShoe24
True Addiction
BigShoe24's Avatar
They worked!
RCC
